Time to Tune up?
Old Jun 23, 2002 | 07:22 AM
RS91's Avatar
Time to Tune up?
I'm getting ready to tune up my car. It's been yrs seen I got it tuned up. My car is a 91RS and has 100K + of miles on it. What are the thing I need to do to get it running right again?
Old Jun 23, 2002 | 08:12 AM
urbman's Avatar
Plugs
wires
rotor
cap
02 sensor
tranny fluid
oil
oil filter
air filter
water bottle (like a windex bottle)
1. Pull the cat...
Your going to run open pipes for a few minutes...
While running...
squirt water into throttle body, not so much that it dies
but you will get some ugly clouds out of the y pipe
2. put the cat back on or replace
add 1/2 to 1 quart of tranny fluid to oil.
Run for a few minutes
stop drain oil, replace filter, replace oil
3. replace plugs, wires, cap, rotor
3. replace 02 sensor
4. replace air filter
5. examine vacuum lines replace as necessary
6. check timing
Evaluate troubleshoot as necessary
Old Jun 23, 2002 | 10:03 AM
Vader's Avatar
... and:
Fuel filter;
Belts;
Hoses;
Cooling system service;
Rear axle service;
Suspension/steering lube;
Body bushing/seal/weatherstrip/hing/latch lube;
And probably other things you discover as you do this.
Old Jun 24, 2002 | 05:39 AM
RS91's Avatar
Thanks for all the info.... What about the knock sensor should I replace it too?
MustangBeater20
Oct 29, 2022 09:20 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
nuggie
Aug 25, 2015 01:27 PM
ezobens
Aug 19, 2015 10:29 PM
355tpipickup
Aug 13, 2015 07:35 AM
