427 build up
Old Jun 24, 2002 | 05:52 PM
Rage13's Avatar
Car: 89 Firebird
427 build up
what combo would you use to get a 427? i know 350 block + 400 crank = 383
so then what kinda crank would you need in a 400 to make 427?
Old Jun 25, 2002 | 08:43 AM
bbunting's Avatar
Car: 1990 IROC Z
Engine: blown 390 CI
Transmission: TKO II
4.125 bore X 4.00 inch stroke= 427.6 CI
4.155 bore X 4.00 inch stroke= 433.9 CI
Old Jun 25, 2002 | 03:33 PM
Rage13's Avatar
Car: 89 Firebird
thanks for the info, what crank would you suggest for a super charged 427 thats going for 800 hp? i'm starting off with a 400 ci 4.125 bore Motown block that has 4 bolt splayed ductile iron mains. any ideas?
Old Jun 25, 2002 | 03:50 PM
bbunting's Avatar
Car: 1990 IROC Z
That depends on your budget. I run an Eagle 4340 in one motor, and a Callies in another.
Old Jun 25, 2002 | 04:05 PM
Rage13's Avatar
Car: 89 Firebird
my budget for the whole motor is about $7000, thats what i'd like to spend anyway, but i'm sure we know how that turns out..
Old Jun 25, 2002 | 04:13 PM
32789RS's Avatar
I'm starting on a nitrous fed 427, I went with the eagle rotating assembly, forged crank, forged H beam rods, and forged JE pistons with moly rings, got the rotating assembly for $1750, I'm just waiting for the block to arive so I can start building it. I'm going with dart block and dart Pro 1 CNC Aluminum heads. I plan on running 10's on the bottle
Old Jun 25, 2002 | 05:04 PM
bbunting's Avatar
Car: 1990 IROC Z
32789RS- where are you at in IA?
Car 1-I have a stock .030 400 block, splayed caps, Callies 4.00 crank, Oliver 6" rods, JE NOS pistons, Dart IRON Eagle 230 CC's, SR cam, EDL SV intake, BG 1000 CFM & 200 HP shot of NOS. 636 FWHP w/o NOS.
Car 2- I have a .070 350 block, splayed caps, Eagle 4340 crank & rods, JE blower pistons, Dart Pro 1 230 CC, SR cam, Accel SR intake, 1000 CFM TB, Accel DFI, 72 lb. per hr MSD injectors, Vortech S trim w/10 lbs boost, NX 150 shot. HP unkown
I did run car 2 lean and hence the .070 bore. 10 lbs+NOS+not enough fuel=bad-even with JE's.
Old Jun 25, 2002 | 07:47 PM
32789RS's Avatar
i'm located in cedar rapids
Old Jun 25, 2002 | 07:57 PM
32789RS's Avatar
bbunting
who did the machine work on your motor? How much metal had to be removed to fit the 4" stroke in a stock block?
Old Jun 25, 2002 | 09:02 PM
bbunting's Avatar
Car: 1990 IROC Z
I am in CR also. Performance Concepts did all the work-machine work and assembly. Also did all the suspension tuning, cage install, Tremec 5 speed from auto swap, etc
They also wrench on my Z06.
Old Jun 25, 2002 | 09:09 PM
gtabadboy's Avatar
Im also trying to get my car in the 11s. I have 5k to spend. I think I want a 383 stroker. Where can I buy it? Should I get a shortblock then add some AFR heads and a cam with huge lift? Any suggestions on where to get any of this. Money is in hand. I want to get in the 11s. I plan on putting in 411 gears a stall converter and running a carb. Supercharging is also an option if budget yields.
Old Jun 25, 2002 | 10:01 PM
bbunting's Avatar
Car: 1990 IROC Z
gtabadboy-the first thing to do is take your time. There are several factors involved to get a car into the 11 second zone.
I would encourage you to talk to some people that are already running 11 seconds or better.
One tool that I use is Dyno2000-a state-of-the-art engine simulation that combines advanced component modeling with the number-crunching power of your PC to test thousands of engine-part combinations, in just minutes! Use the Dyno2000 to easily find the best setup for your next street or racing engine project.
Then import your engine into Drag2000 to find the best gear ratios, suspension setups, shift points, and launch RPMs for drag racing, circle tracks, road courses, or auto-cross competition. You can even practice and fine-tune your reaction time and shifting skills using our full-featured starting-line and full-track simulation Full Throttle.
As far a an engine combo, adding heads and a big cam is not necessarily the recipe for success. A pump gas friendly 383 can easily top 500 HP. With good forged pistons, a shot of NOS, traction, 11's are realistic for your budget-always keep 15-20% extra $$ for those unexpected surprises that are inevitable.
I buy most parts online-look at some of the site sponsors.
ZEEYAA
Apr 16, 2023 08:29 PM
racereese
Oct 3, 2015 03:46 PM
92projectcamaro
Sep 29, 2015 07:07 PM
Zell1luk
Sep 29, 2015 10:36 AM
Jlanz55
Sep 29, 2015 08:55 AM
