O2 Sensor replacement
Old Jun 25, 2002 | 06:26 AM
Chipguy's Avatar
Two questions regarding O2 Sensor replacment on my 1991 Pontiac Trans Am.
1) How do you know when it is time to replace it other than when you recieve a code ? My car has 65K original miles.
2) How do you replace it ? Do you need any special tools ? This may sound strange but I want to keep it intact when removed ( I keep all the OEM parts) so I don't want to cut wires or break it off. Do I get to it from the top or from under the car ?
Thanks for input...
Chip
Old Jun 25, 2002 | 06:31 AM
deadtrend1's Avatar
Ways to know : code will be set off ... gas milege will suck ...... the idle will be rough .. you take it out and it looks funky shades of black.
You can buy the special tool thats around 10 bucks that clips on to a socket wrech to remove the sensor.
Then you unplug the senor from the wire and plug the new one in. Its simple really. (just don't do it right after you just drove your car to buy it :nono: )
~Tim
Old Jun 26, 2002 | 12:37 AM
89WS-6's Avatar
no special tools required, mine is probably the same as everyone elses, and it looks to be about a 1 inch hex nut. Easy shmeesy.
Old Jun 26, 2002 | 12:41 AM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
3/4 inch if I remember correctly
Old Jun 26, 2002 | 12:59 AM
rezinn's Avatar
7/8" wrench needed, or a 7/8" socket with the side cut off (called an oxygen sensor socket, duh). 60k is the interval for our cars, so you're overdue. Make sure the exhaust is warm when you pull it out, it will make things much easier. Also make sure the new one is sealed and has antiseize on it.
Old Jun 26, 2002 | 09:31 AM
Buck268's Avatar
Its a pain in the *** to try to use an open ended wrench like some people will recomend. I tried, it just doesnt work. Go to autozone, and rent a O2 sensor socket. Also, let that thing soak up a bunch of Penetrating Fluid, nd get a breaker bar, it'll be somewhat rusted in place!
Old Jun 26, 2002 | 10:06 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I hate o2 sensor sockets. Too flimsy. I cut off the wire and use a good old deep well socket for removal, but since you want to save your crusty old one (do you save your old oil?), you'll have to settle for the o2 sensor socket.
Old Jun 27, 2002 | 10:16 AM
Vader's Avatar
I'm with Jim. Either fold up the sensor lead and connector into the deep socket or cut the wire off.
When you get your supplies, don't forget a small jar of anti-seize compound. The amount supplied with the new sensor is never quite enough. Just keep the excess compound off the sensor tip.
As for the first reply, another way to determine if the sensor needs replacement is if you haven't already done so within the last 30-40,000 miles.
bamaboy0323
Sep 3, 2015 06:07 AM
91REDZ28VERT
Aug 18, 2015 10:16 PM
mizz0313
Aug 12, 2015 06:45 AM
92purpz28
Aug 11, 2015 02:30 PM
