Shifting problems
Car: 99 Formula
Axle/Gears: 342
Originally posted by ede
check the fluid and filter, adjust the tv cable
is it a 700r-4? if so have you changed the tranny fluid lately?
every single time i change my fluid it starts slipping.everytime!!!i change it every15000-20000miles without delay everytime it will slip for about a week or so! this time when i changed it at 40,000 miles its slipping AGAIN! and this time its saying goodbye im going out!!!!700's suck shlong!!
Car: 1990 Trans Am
Engine: Lb9
Transmission: factory T5
Axle/Gears: 3.08 limited slip
arent 700's just wonderful? I love overdrive and the first gear ratio, but the reliability on the is very iffy, their biggest problems are either going to complete trash, or burning up from heat, check fluid level and pull the pan and look for tiny shiny metal chips
Thanks for all the responses guys!
Drove it to work today and it was fine.Shifted normal..
Last night I did a doughnut around the parking lot at work,and thats when it started acting up..May be I stretched the tv cable or something..Tranny fluid is full and only has about 9000 miles on it..
someone972
Aug 30, 2015 12:52 AM
dhonda200
Aug 11, 2015 11:50 PM
