cam swap
Old Jun 26, 2002 | 08:41 PM
tommy follin's Avatar
cam swap
i have a 1991 camaro rs with a 305 tbi all stock. i'm going to add a flowmaster exhaust cat back system, long tube headers and, a intake.and 411 gears . which cam should i use?
Old Jun 26, 2002 | 11:31 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
i believe theres a better board for this where you 'll get more answers.......your headed there now
Old Jun 27, 2002 | 02:25 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I'm pretty sure everyone that will respond will say use the LT1 cam.
Old Jun 27, 2002 | 02:34 AM
rezinn's Avatar
If you're getting long tube headers don't bother with an LT1 cam, get something bigger. You're probably going to need some head work to handle the new cam, so you better look into that also.
I'd take a look at the comp cams website maybe, I'm too tired right now or I'd look for you
Old Jun 27, 2002 | 09:50 AM
Car: 99 Formula
Axle/Gears: 342
Aren't long tube headers going to be a pain in the butt for an install?
Old Jun 27, 2002 | 08:10 PM
kfoley's Avatar
Car: '85 Z28
Transmission: WC T5, 3.23 posi
He'll most likely have to either pull the engine, or lift it up, and he might have to make some modifications to the floorpan/tranny depending on what brand he gets.
anesthes
Mar 10, 2016 10:35 PM
beastin91rs
Oct 9, 2015 07:38 AM
Cameeeero
Sep 18, 2015 04:00 PM
theshackle
Aug 22, 2015 06:52 PM
theurge
Aug 21, 2015 12:46 PM
