What temp should my car be running at stock?
Old Jun 27, 2002 | 04:36 PM
87350IROC's Avatar
Car: 87' IROC
Also, I have seen that a lot of you have cooler running thermostats, why? The engine shouldn't be cold all the time right? Also, what thermostat do you recomend and how much does it cost and how do you replace it?
John
Old Jun 27, 2002 | 05:02 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
The fan doesn't turn on till 227* or so.
A cooler engine will produce more HP, but for emission purposes were designed to run warmer.
With a CC car I would go with a 180* stat.
You can get a stat and gasket for like $6. To locate it follow the upper radiator hose from the radiator to the intake manifold. Under the thermostat housing is the stat.
Old Jun 27, 2002 | 05:04 PM
SpeedCat86's Avatar
Car: '86 TransAm WS6
Transmission: Custom TH700R4
Should be around 225 or so, stock. That's why the 220 is in the middle of the stock temp gauge.
My car has a modified 195 degree thermostat and it runs at about 210, unless I get stuck in really bad traffic, then it climbs up to about 225. My current setup consists of a Stewart StageII pump, a new stock radiator, and the aforementioned thermostat.
The hot setup for thermostats is the Robertshaw unit. Mine is modified with three 1/8" holes to allow for a small amount of coolant flow before the thermostat opens. (StageII pumps don't have a pressure bypas)
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
camaro71633
Sep 1, 2015 10:24 AM
marcusaw
Aug 10, 2015 08:13 AM
Exxon Limited
Aug 9, 2015 08:13 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
