Oil in distributor?
Old Jun 30, 2002 | 08:01 PM
junglecat's Avatar
Oil in distributor?
Found an oil leak around the distributor so I thought it might be the seal but the oil is inside the distributor leaking out. Any ideas what my problem might be? Junglecat
Old Jun 30, 2002 | 09:03 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
if its leaking where the dist meets up witht he intake, its the little seal there. Not too bad to replace. Mark off where the rotor is pointing and lable and disconnect all wires and pull it out. put a new seal on the part of the intake where the dist. rests, replace dist. and check timing.
Old Jun 30, 2002 | 09:07 PM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
There is also an O ring in the dist. shaft.... check that....why you have the distributor out.
Hotrodboba400
Dec 10, 2019 07:07 PM
camarohelp
Sep 22, 2015 03:19 PM
Gunsbee
Sep 7, 2015 07:10 PM
Jlanz55
Sep 6, 2015 03:05 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
