car smells like gas after/while running
Old Jul 1, 2002 | 09:55 AM
Brian'sIROC's Avatar
my car smells like gas after/while running. The smell seems to be coming from the back of the car. I've checked the whole fuel system all the way back to the fuel filter and have found no leaks. There is a small tube coming out of my gas tank that looks like a small breather. Could this be why I'm smelling gas?
Old Jul 1, 2002 | 10:14 AM
ede's Avatar
ede
check to see if your charcole canister is saturated
Old Jul 1, 2002 | 10:40 AM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: Pro-Built Automatic/Vigilante 2800
How do you check it?? Just flip it over and see if its wet??
Old Jul 1, 2002 | 11:33 AM
ede's Avatar
ede
takt it loose and shake it, if it has gas in it youy ought to be able to hear it
Old Jul 1, 2002 | 12:34 PM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
and what if it does, will it require replacement??
Old Jul 1, 2002 | 01:09 PM
Blackened's Avatar
Uh huh
Old Jul 1, 2002 | 02:01 PM
redbird_400's Avatar
Car: 89 Formula Firebird
Engine: 305 - Demon 525
Gas smells good. Hehe what is it a strong smell or just a light smell?
Old Jul 1, 2002 | 02:59 PM
it's a pretty strong smell. If it was the canister why would the smell come from the rear of the car? I'll check it anyway when I get home. Would I have to replace the whole thing or is there a valve on top that can be replaced?
Old Jul 1, 2002 | 03:25 PM
john5.7 87Iroc's Avatar
Car: An '87 Italian Retard Out Cruisin'
Engine: LS1 install in progress
Transmission: 4L60e
Axle/Gears: 9 bolt
This is the valve coming off the tank.. Mine broke and I smelled feul all the time. Just pull it off the line its hooked to and blow through it or shake it. Mine was completely hollow. New one from the dealer is like $10
bryan623
Mar 22, 2021 06:43 PM
mustangman65_79
Sep 1, 2015 03:51 PM
kyleb24
Aug 15, 2015 08:24 AM
Sherpajames
Aug 7, 2015 06:56 PM
