Water Pump
Water Pump
Yes, I know that I should go ang look, but it was dark and I couldn't really tell. I think I blew out my water pump last night. Water everywhere, under the car AS WELL AS on top of the engine in a fan-shaped pattern. Likelyhood of it being the waterpump?
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
Usually the "weep" hole under the bearings in the water pump is the source of the leak.If it's coming from there you might as well get a new pump.
-Rich-
-Rich-
Car: 1988 Camaro SC
Engine: 305 TBI
did you smell any coolant burning? I had been driving for a decent time so the engine was good and hot... water pump took a crap and i could smell the coolant burning inside the car (thank ***) so i shut it down real fast. Then i left a puddle.
like Rich92RS350 said; if its leaking out that weep hole on the bottom... your screwed.
get a new one.
They're only like 50 bucks from NAPA around here; full lifetime warranty...
get a new one.
They're only like 50 bucks from NAPA around here; full lifetime warranty... Thread
evilstuie
Jan 9, 2020 08:29 PM
Dialed_In
Aug 20, 2015 01:45 PM
