Just how bad are stock 87 LG4 heads?
Old Jul 4, 2002 | 10:21 PM
Xenodrgn's Avatar
Will they work with a mild-cammed and headered 305, or should I port them...
Or are they that bad that I should invest in new heads. If so, what ones should I invest in with 1.5inch primary headers and the Comp Cams 260 cam. Stock intake and CC Rochester carb.
Someone mentioned World Torquers... Is there anything cheaper that will get the job done? Will a split pattern cam like the XE series cams help compinsate for the LG4 heads? Or are they still going to be a bottleneck?
PS this is a 5-speed car, with a 3.42 rear.
Can anyone run this combo on DD2000 and give me figures?
Old Jul 4, 2002 | 10:26 PM
iroc22's Avatar
F-BIRD'88 had good success with porting his 416's I believe.
Vortecs are a little cheaper to buy, but then you have to buy the required intake that will put them at the same price as the World's.
Old Jul 4, 2002 | 10:32 PM
Xenodrgn's Avatar
Also, with the stock heads, will I need screw-in studs for the 260 cam, or the split pattern XE262?
Springs, retainers, locks, seals and, a timing set are a given...
Old Jul 4, 2002 | 10:33 PM
Xenodrgn's Avatar
I take it that 416's are the stock heads in that year LG4?
Old Jul 4, 2002 | 10:39 PM
iroc22's Avatar
Yeah sorry, shoulda mentioned that. How much lift does that cam have? I dont think you will need screw in studs. The stock 'lift out' (Vader) studs should work fine.
Old Jul 4, 2002 | 11:32 PM
Xenodrgn's Avatar
Forget it, I'm going with the HE260. the dual pattern is going to cause too much torque loss, the 5speed will let me control things...
the 87 305 is a roller block isn't it?
****, that means I need to find a hydraulic roller camshaft...
Old Jul 5, 2002 | 12:37 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
416's weren't the stock heads in 1987. '86-earlier, yes.
Why are you asking about '87 LG4's? Do you have one you're building? '87 will be roller block, one-piece rear main, center bolt valve covers, center two intake bolts on each side at a different angle from the others.
Old Jul 5, 2002 | 01:12 AM
iroc22's Avatar
Oh whoops, I missed the 87 part hehe. Yes roller block means you should get yourself a roller camshaft for the 87-95 SBC's. You could run a flat tappet cam, but you'll need different length pushrods.
yeah the 87 LG4 is an entirely different animal
Old Jul 5, 2002 | 01:13 AM
Xenodrgn's Avatar
I might be swapping an 87 LG4/T5 set-up into the Sport Coupe... (rather, having it swapped... however you wanna look at it... 1991tealRSt-top is going to be the leader, I'm going to help out as much as I can...)
The minds of the heads I scratched as well as my own are a little foggy, but I believe it's an 87 car.
I'm just trying to plan this whole thing out in my head as I go... collecting parts and what not...
And before you jump on me about the swap-in-a-350 BS... when you can get a running/driving/in-the-car setup for no more than $200, you jump on the opportunity, especially when you have a dying V6 and 700R4 setup in your car now...
Old Jul 5, 2002 | 01:15 AM
Xenodrgn's Avatar
A good different animal, or a bad different animal...
What are it's weak points... cam, heads? Intake, carb?
Are the heads on it going to be good enough for a mild cam and headers? Or do they need to be ported, should I slap ported 416's on it instead? Should I port the stock 87 lG4 heads?
Old Jul 5, 2002 | 02:10 AM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
LG4s are excellent--once you dump the exhaust, heads, intake and cam
Port and polish your own heads! We have a lot of folks right in the middle of it right now, so look at the other threads dealing with this and join right in. F-Bird'88 is tutoring the lot of us on this, so take advantage of his expert help.
We've discussed all of these points. You arrived at the perfect time
Old Jul 5, 2002 | 03:52 AM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
xenodragon............if you can wait a month or two, i can sell you my LG4 heads...............jeff had them ported pretty well..........i just need to put the heads i am buying today on...................
Old Jul 5, 2002 | 03:53 AM
btw, how much can i ask for a set of stock LG4 heads that need to be rebuilt (these arent the ones i will sell you, xeno, dont worry)
Old Jul 5, 2002 | 03:55 AM
.....and a friend who is going to do the swap for free......
Old Jul 5, 2002 | 01:03 PM
iroc22's Avatar
They'll need to be ported, the '081' castings are very similar to the '416' castings. However if it was up to me, I would go with the '416' castings just because of their compatibility with more aftermarket intakes. The centerbolt design seals better around the cover, but the fact that the 87-95 intake design requires more expensive and less popular intakes is kinda a downside.
Old Jul 5, 2002 | 03:13 PM
five7kid's Avatar
The cost of shipping.
At least, that's what I'm offering for the set of 416's I've got.
Oh, the '87-later "good" 305 heads are the 081 casting. I have one of those with one cylinder already ported...
Old Jul 5, 2002 | 03:19 PM
Engine: 305-4v
Taking up room in the garage, eh Tim?
Old Jul 5, 2002 | 03:42 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
This can easily be over comed by slotting the holes.
Old Jul 5, 2002 | 04:34 PM
iroc22's Avatar
Or by getting the centerbolt conversion kit from GMPP to make the perimeter heads into centerbolt. Either way it can be done.
theshackle
Mar 5, 2017 06:37 PM
gta90
Sep 15, 2015 04:00 PM
camaro71633
Sep 1, 2015 10:24 AM
NinjaNife
Aug 23, 2015 11:49 AM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
