Vortec Heads, Intake, block.
Old Jul 5, 2002 | 03:25 PM
Dolph88sc350TPI's Avatar
Car: 88 Camaro SC, 86 T/A, 92 Eclipse
Wondering if you guys could help me out a bit....
Is there any improvements in the vortec block by itself?
It has a roller cam right?
Can i use full roller rockers on vortec heads?
What kind of rockers are on a stock 98 vortec engine?
What exactly is the difference in a vortec intake?
I know thats alot of questions, but any help would be greatly appreciated.
Old Jul 5, 2002 | 03:38 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
The Vortec block is basically the same. If it's out of a 2500 or larger truck it will be a 4 bolt main. 95 & up have hyd roller cams. To use roller rockers without modifcation, you will need the self aligning type. The stock ones are stamped steel, self aligning, non roller type. The Vortec intake ports are taller than standard with a different bolt pattern. A standard intake will not cover the intake port without serious modification (welding & redrilling).
Old Jul 5, 2002 | 03:43 PM
How difficult is it to bolt the vortec heads and intake to an older sbc?
Is it possible to use a hyd roller cam in an older sbc?
Old Jul 5, 2002 | 04:08 PM
bhaas's Avatar
Voretecs will bolt right on no prob. But you will need a Vortec specific intake and if you plan on using a cam with .480 + lift plan on getting new springs and the valve guides cut down a bit. If you don't want to pay the insane price for self aligning rockers then you need to get screw in studs and guide plates and hardened pushrods. I used K-motion K-700 springs in mine also.
Brad...
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
Tinbender59
Mar 17, 2017 10:50 AM
L98GTA87
Aug 11, 2015 06:55 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
