Throttle Position Sensor Error
Old Jul 12, 2002 | 10:14 AM
TransAm's Avatar
From: Somewhere in between Lynn, MA (home) and Lakeland, FL (school)
Got this code (23) yesterday for no apparent reason. Car still runs fine. Part costs $50... how bad do I need it? Where precisely is it located?? Does it most likely need replacing? What does it do.. aside from sense the throttle position?
Thanks a lot,
Old Jul 12, 2002 | 10:58 AM
87transam5.7tpi's Avatar
the TPSis on the passenger side of the throttle body. it is kinda like a triangle and has 3 wires going to it.
Old Jul 12, 2002 | 10:59 AM
TransAm's Avatar
It's an LG4... carbeurated.
Old Jul 12, 2002 | 12:52 PM
83tranzam's Avatar
Car: 1985 Trans Am
Engine: LB9 5.0 TPI
I guess i'd see how long you can hold on without it. When my TPS went bad on my old 2.8L Camaro, the car would drive fine, but stall out at idle & right before the car came to a stop. Ah, memories....that car was always throwing a code for one reason or another
Old Jul 12, 2002 | 12:59 PM
83tranzam's Avatar
Car: 1985 Trans Am
Engine: LB9 5.0 TPI
Almost forgot. It's located right next to the carburator...that's as specific as I can remember without having the Chilton manual right here....I remember seeing it in there when looking at something for my carb. Sorry so vague, but hope it helps.
someone972
Aug 30, 2015 12:52 AM
Bert87
Aug 23, 2015 03:50 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
