tell me if my power steering pump is going?
Car: 92 Z28 Z03
Transmission: 700-R4
Axle/Gears: 2.73 G80
so im driving down a windy road and i hear like my tires are coming off the road you know the sound when u go fast around a corner. but im going slow. then later on if felt like the steering wheel was rubbing the collum. it also felt like the steering wheel was vibrating when i was turning at 5mph. also the car turns better in gear then when i try and turn in neutral. i never noticed a difference before now i do. so what do you guys think?
Car: 92 Z28 Z03
yea it was like a whining but it was worse in netual in reverse. I'll check the fluid tommorrow its all dark outside.
Thanks for the help!!
Car: 92 Z28 Z03
i checked it and it was low so i added some. Where about would I look for the hose? the last time i put some in was a month ago. so i guess i have a leak then. where should i look.
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
the hoses go from the power steering pump, to the steering box. they are high pressure hoses, and may only leak when you are turning....Start the car and inspect this area...have a friend inside the car and move the steering wheel left and right..as you look for leaks...the fluid will look like tranny fluid. If it is a hose, you will have to replace it, they run about 20.00 new at napa.
Car: 92 Z28 Z03
I didn't see any of the hoses leaking. Would they leave a puddle on the ground? I had to add more fluid again today. so im assuming is leaking pretty good. where else should i look for a leak?
thanks
thanks
Engine: 406
Like I said, you need to have a friend turn the wheel while the car is running..while you look for leaks...if it isnt the hose it must be the resevoir....those two places are the only place it can come out of...hoses...resevoir.....The car has to be running to create pressure..while the wheels are turning.....try this and see what happens.
I guess the steering box itself could leak, but Ive never seen it. As for a puddle....it most likely is leaking only when being operated...Im sure its a very small leak.....big ones a VERY easy to find.
Car: 92 Z28 Z03
so i figured out where it is leaking and took some pics. Also im going though a bottle of power steering fluid every 2 days. So can someone give me a heads up on my problem about what it is and how much it is going to cost?
Car: 92 Z28 Z03
one more thing, it is leaking out of the bottom of the thing the white arrow is pointing to.here are more pics...
Car: 92 Z28 Z03
yea it is leaking from the bottom of the thing the white arrow is pointing to. how much $ to fix
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
I couldn't tell ya. Most people just install a rebuilt steering box and call it good. Those are significantly more expensive than a power steering pump or hose. You're probably looking at $200-$300 for a replacement, depending on what you get and where you get it.
You are going to want to take care of it though. if the PS pump or hose goes, you usually just lose your power assist. If the box goes, the steering can practically lock up on you. I know, I had that happen--took BOTH people in the car to turn the wheel.
From: Tucson AZ where the 3k ft of elevation kills your time
Car: 89 camaro rs
Engine: 383 .06 over
Transmission: th350
Axle/Gears: 3.73 10 bolt
junkyards my frind, junkyards you can get it done there for cheap, just make sure that they don't lieve you steering weel crooked. i got mine fixed at a junkyard for 200 but i didn't notice that the steering weel was crooked untell it was to late
but this was on my dads truck and i believe that in our cars you can only put all the steering parts on in one perticuler order so they won't end up that way, but i am not sure
but if you get it done at a junkyard just look at your steering weel and two front weels before you lieve and make sure that they are strat.
but if you get it done at a junkyard just look at your steering weel and two front weels before you lieve and make sure that they are strat. Thread Starter
Car: 92 Z28 Z03
so i should get a new steering box installed? if it is the pitman seal how hard is that to fix? Casue i have to try and get this fixed soon. i can tell that my steering is not as tight as it was.
Car: 89 camaro rs
Transmission: th350
well if you buy a steering box you might be able to instale it yourself but if you try to get the pit men seal raplaced it is labor that is going to coast you more money so it would be better and cheaper to have the hole thing changed
Changing the steering box is a pretty frustrating job. That damn thing is heavy and hard to maneuver into such an awkward place, much less get the bolts started. If you have someone to help you it's not that bad.
Worst part is trying to get the old pitman arm off. Usually it's pretty well attached. Last time I did it I just bought a new arm after beating on it for three days.
Car: 92 Z28 Z03
so its probably best just to get a new steering box? think i should try to pick one up at a junk yard for cheaper? Then i just will bring it to a shop to get put in? sound like a good idea?
colton_carlson
Mar 8, 2019 12:21 PM
backtothe80s
Sep 5, 2015 12:39 AM
