Any Reason I can't put valve seals
Old Jul 15, 2002 | 02:02 PM
Rat 427's Avatar
I have a car that smokes only on startup, doesn't burn a drop while driving. First guess is valve guide seals. Picked up a kit and start changing them to find out there are only rubber mushroom seals on the intake. OK thats fine, it won't burn oil whil driving, but why aren't they on exhaust for when the valve guides start wearing. I think this is letting oil drip down the exhaust valve when parked for long periods of time allowing smoke on start up.
Is there any reason I can't put the rubber mushroom seals on the exhaust also, they fit right on the bosses.
thanks,
Bruce
Rat427@aol.com
Old Jul 15, 2002 | 02:23 PM
ATOMonkey's Avatar
Good 'ol gm decided that only the intake side needed umbrellas. The only way to reseal them is to use the umbrellas on both sides. Before GM acknowledge this was the right way, the fix was to use Ford seals, because they came with all 16 umbrellas.
1992 Trans Am
May 10, 2023 07:19 PM
gta90
Sep 15, 2015 04:00 PM
86White_T/A305
Aug 17, 2015 12:16 AM
Leggman1
Aug 6, 2015 04:15 AM
