I think I finally found my problem!!
Old Jul 15, 2002 | 08:28 PM
Paul Riccioli Jr's Avatar
Car: 89 IROC-Z
Engine: 383
I think maybe I'm using the wrong thermostat with my chip or it's reading the CTS funny. I disconnected the CTS plug tonight after a mechanic friend recommended it. The problem didn't go away totally, but got like 10 times better!! I'm going to call Ed Wright tomorrow and discuss it with him......finally I think I have it!!
Old Jul 16, 2002 | 10:13 AM
Vader's Avatar
Paul,
Check the resistance of the CTS at a given temperature. Compare it to the table to determine if the CTS is good. ± 50 ohms is usually O.K.:
Old Jul 16, 2002 | 08:25 PM
Car: 89 IROC-Z
Engine: 383
Vader,
I am putting a scanner on it tomorrow as well as getting a laptop for the week so I can run WINALDL on it. I was also reading a post about injectors bleeding off. When I turn my key on the fuel pressure goes up to the correct setting, but then slowly comes down to like 25-35, maybe lower if I left the gauge on it long enough. Is that a problem???
Old Jul 16, 2002 | 10:33 PM
Vader's Avatar
How long fpr the fuel rails to drop 10 PSIG? If the pressure drops in ten minutes or less, you may have a leaking injector(s) or regulator, or possibly a pump check valve leaking back. You should be able to isolate the leakage by pinching shut the supply and return lines one at a time to isolate parts of the system.
aaron7
Aug 17, 2016 06:02 PM
Polo Z03
Sep 10, 2015 06:43 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
bjpotter
Aug 12, 2015 06:06 PM
antares57
Aug 6, 2015 07:47 AM
