Alternator overcharging- should I panic?
Old Jul 16, 2002 | 12:20 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Well this goes along with the "taking a long trip soon" idea, just like my "Fuel filter replacement cause fuel pump death?" question. My alternator is charging at 14.30 volts... yeah, that's not much more than 13.8, but is it too much more? At idle with nothing on, it was charging up at about 12 amps... with the headlights on (low beam) and the heater motor on high, it went up to about 30 amps. This was measured with one of those "hold the meter near the wire" meters... I measured the charging voltage with my Fluke.
Should I panic and replace the alternator before this trip of mine? Or will it be alright?
Old Jul 16, 2002 | 12:47 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
That all sounds about normal to me... most alternators are designed to attempt to keep about 14.2 volts on their sense lead... you can spend your worry on other more important things, like tire inflation and coffee-cup holders / thermos and enough new CDs to keep you from getting bored and stuff like that
Old Jul 16, 2002 | 01:11 PM
ede's Avatar
ede
yeah all my cars/truck with gauges read right under 15. i wouldn't worry about it, sounds normal to me.
Old Jul 16, 2002 | 02:28 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Great! Thanks again, guys! (The fiance isn't going to like my CD collection, though. Any tips for that one? At least she won't argue against the Zeppelin cd's...)
Old Jul 16, 2002 | 02:57 PM
88TPI406GTA's Avatar
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
I would be concerned when it gets closer to 15 volts...but you are fine to at least 14.5...
The range is 13.8 to 14.3 normally...so you are close...
HTH,
RS Reaper
Oct 17, 2018 07:52 PM
apie2546
Oct 16, 2016 02:24 PM
SRKLEGIN
Oct 3, 2015 10:11 PM
RS Reaper
Sep 27, 2015 07:04 PM
raymondandretti
Sep 27, 2015 06:43 PM
