ticking
Old Jul 18, 2002 | 03:18 PM
uidzer0_z28's Avatar
ticking
Hey guys,
I have been noticing a quiet ticking noise coming from the drivers side of the engine, it is pretty constant and I hear it the loudest at about 1500 rpm.
Any ideas as to what this is?
Thanks,
Ben
Old Jul 18, 2002 | 04:40 PM
Brian'sIROC's Avatar
It can be many things. The most common would be an exhaust leak.
Old Jul 18, 2002 | 05:25 PM
it is not an exhaust leak, it sounds like it is coming from inside the motor heh... I don't know--> how do i check to see if a rocker is loose?
Thanks,
Ben
Old Jul 18, 2002 | 05:56 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I would check for a collapsed lifter, but never rule out an exhaust leak. Unless the sound goes away.
Old Jul 18, 2002 | 07:32 PM
CaysE's Avatar
Most likely the sound is a tapping pushrod, caused by a loose rocker or a sticking valve.
Old Jul 18, 2002 | 07:36 PM
Car: 99 Formula
Axle/Gears: 342
I'd suggest taking off that air cleaner. I had one on my old Stang, backfired and burnt the foam and sucked it into the carb.
Old Jul 18, 2002 | 07:50 PM
Hulk0202's Avatar
Before you rip your engine apart, check the pcv valve. It ticks very quietly.
Old Jul 18, 2002 | 09:51 PM
thanks Hulk! that was it
-Ben
Mark: thanks, i saw it backfire tonight and thought about that, after the races this weekend I am gona do that(poor right now)
thanks again!
Old Jul 18, 2002 | 09:56 PM
Hulk0202's Avatar
Glad I could help.
david068513
LSX and LTX Parts
Nov 15, 2015 11:37 PM
meeklay812
Oct 1, 2015 03:46 PM
corey8084
Sep 17, 2015 02:56 PM
david068513
Sep 13, 2015 11:24 AM
david068513
South East Region
