car won't go :(
Old Jul 21, 2002 | 01:48 AM
dziabo's Avatar
car won't go :(
i have an 84 z28 with a carburated 5.0L engine and a 700R4 tranny. the car starts fine and idels ok. when i put the car in gear it will start to go, but then the rpms drop and the car starts to stall. if i give it more gas it will kind of chug down the road but it will only go like 10 or 15 mph. if i don't give it more gas, it will just stall out completely.
i rebuilt the carburator and installed a shift kit, but that was almost three months ago and it ran great till now, so i don't know if either of those are the problem.
i don't know what to do so any help would be greatly appreciated.
Old Jul 21, 2002 | 02:09 AM
radiateu2's Avatar
have you checked the fuel pump and vacuum lines?
Old Jul 21, 2002 | 02:11 AM
radiateu2's Avatar
I wonder if your float or needle valve is hung up and the bowl is running dry
Old Jul 21, 2002 | 03:01 AM
dziabo's Avatar
i tried putting a new fuel pump on and that did not work.
when the car is in park it revs up just fine, but when i put it in gear, it starts to mess up. could it still be a carb problem if it revs up ok when it is not in gear?
Old Jul 21, 2002 | 06:28 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
sounds like fuel delivery
check your fuel filter, inside the big nut the fuel line scews into
Old Jul 21, 2002 | 11:00 AM
TA5LiterHO's Avatar
Car: 1984 Trans Am WS6
Transmission: 700r4 Highly Modified
Question. You don't have a Quadrajet Electronic Carb do you? Because, my 84 Trans Am used to have one and when the ECM goes bad the car used to do exactly that. Except mine would start then cut off after like 30 seconds. If you have that carb and it's doing that, replace the ECM it will run fine. If you don't have that setup, it is probably a fuel delivery problem like was already stated. Or one of the floats in the carb is messed up.
Old Jul 21, 2002 | 02:53 PM
dziabo's Avatar
how do i know if it's an electronic carb?
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
ZsTransAm
Aug 11, 2015 07:30 PM
ryanz281988
Members Camaros
Aug 8, 2015 06:45 AM
kyle5647
Aug 7, 2015 03:08 PM
