What kind of open air cleaner??
Old Jul 21, 2002 | 06:02 PM
91redbird350tbi's Avatar
Hi guys,
I am wanting to get an open air element. I went to the part store today and there is a 14in and a 10in. I was going to get the 10. Its a Holly something. My question is what kind would be best for my car. 1 firebird 350 tbi. What do you recommened. Any info would be greatly appreaciated. Thanks
Old Jul 21, 2002 | 06:10 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I'd go with the 14" it will flow more air. I would think that a 10" wouldn't look as good either.
Old Jul 22, 2002 | 04:44 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
I would use the 14" as well. If you have the stock F-Body TBI, the nyour air cleaner should only have a single wing nut, just like a carb. Edelbrock part# 1207 will work just fine (autozone sells this one for $25) It is a drop bsae 14X3", so it clears the hood fine. I have this one on my car, and my friend has the exact same one on his 89 Firebird 305TBI.
There is one thing to look for, though, look and see if your stock air cleaner has a sensor in it. This is the IAT (Incoming Air Temperature) Sensor. If it does, the check engine light will come on when you disconnect it, and you must follow the instructions on this page
http://snflupigus.tripod.com/step3.htm
to jump the sensor plug with a 7.5K ohm resistor. If you can't find a 7.5K ohm resistor anywhere, you could use something like two 3.5K ohms, or 2 4K Ohm resistors, just as long as you connect them in series, not paralell, and the sum of the resistors is about 7.5K ohms.
Old Jul 22, 2002 | 06:30 AM
MX265
Guest
Posts: n/a
Or you could just punch a hole in the bottom of the air cleaner and leave the IAT sensor installed. Just a thought.
Old Jul 22, 2002 | 12:22 PM
Thanks for the info. I am on my way to get the 14 inch air cleaner. I will let you know how it works out. Thanks Jared
Brinkkl2000
Aug 4, 2018 08:29 AM
86IROC112
Sep 7, 2015 01:37 PM
BurlyChev
Aug 22, 2015 01:52 PM
wruiz
Aug 13, 2015 09:07 PM
92purpz28
Aug 11, 2015 02:30 PM
