wires for 6al??
Old Jul 23, 2002 | 01:13 PM
89formula#1's Avatar
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
wires for 6al??
hey guys i am gonna be ordering my msd 6al ignintion soon cause i am switchin to carb and i was wonderin if i need a certain type of plug wie with this box? i remember once hearing that i need spiral core wires with it but i don't see why i do. woudl the accel super stock 8mm wires work fine? thanks
Old Jul 23, 2002 | 01:32 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Don't buy the 6AL for your car. It is a waste of money. You don't need it for a carb. Carbs have been working fine, almost as long as fuel injection, without one.
You do however need a non-computer-controlled distributor. Spend your money there instead of the MSD box.
Taylor Spiro-Pro wires are my preference.
I do not use a 6 AL.
Old Jul 23, 2002 | 01:56 PM
Car: 89 Formula
Engine: Carbed 5.7
i wasn;t asking if it was a waste of money i was asking wut kind of wires i need for it. i alreayd have a hei dist. and maybe u knwo sumtin i don't but don;t i need to have an ignition box? cause my car is a tbi and i am not gonna have a computer or anything like that so i have to have the msd right?
Old Jul 23, 2002 | 02:34 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
No you don't need the MSD. You may want it, but your car doesn't need it. If you have a non-CC HEI it will work just fine without it.
Old Jul 23, 2002 | 02:58 PM
Car: 89 Formula
Engine: Carbed 5.7
ok well u know more then me so i am about to thank u for saving me 200 bucks but first i need to ask one question. i wa slooking at my distributor its the summit hei and i saw the ignition module's for an hei dist in my summit and took off my cap and rotor an started lookin. well i see wut the ignition module is and i was wonderin if when i crank the engine it spins the dist. making electricity then it goes to the ignition module then to the coil and then to the rotor and sparks and starts the engine. now is this right or will i need something else to get the engine to start or do i just drop the dist. in and it will start rigth up? also would it be worth it to spend 40 bucks and get the pertrnix flame-thrower ignition module for hei just to give it a little extra power or would there not be a diff? oh and one more thing, would an msd cap and rotor help or no? man thank u so much u are a life saver
Old Jul 23, 2002 | 03:10 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
That's pretty much it. All that the MSD box does is amplify he signal the module sends to the coil.
As long as the distributor is dropped into the engine correctly, it will run.
I would not bother with any special modules, at least not until after the car is running properly, and probably not even then. Keep the number of variables you have to troubleshoot at startup to a minimum. You can always swap it later if you want to.
A new cap & rotor when putting in a used distributor is always a good idea. The MSD ones are good quality and will work fine.
Old Jul 23, 2002 | 03:14 PM
Car: 89 Formula
Engine: Carbed 5.7
well i have a brand new summit dist. so the cap and rotor are new so i will just leave them till later on then maybe i will switch. well thanks u so much for all your help.
Old Jul 23, 2002 | 04:33 PM
ronterry's Avatar
Car: '94 Corvette
Wait a second 'RB83L69' my distributor doesn't have a module. The MSD is the module/multiple spark/capacitive discharge/rev limiter
Yes, the Accel 8mm will work fine.
I used Accels 8mm on DFI, and they worked good.
Ron
Old Jul 23, 2002 | 05:29 PM
evil t/a's Avatar
Ron
Exactly in noncomputerized HEI aplications the module is removed and the msd is run directly to the pick up, and there is a difference in performance.
Old Jul 23, 2002 | 06:34 PM
Car: 89 Formula
Engine: Carbed 5.7
ok well i hope u were right because i just ordered jegster subframe connectors instead lol
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
Bert87
Aug 23, 2015 03:50 PM
