might not be tech but im pissed so im posting
Old Jul 23, 2002 | 01:30 PM
83CAMAROMAN's Avatar
Car: 1983 Camaro Sport Coupe
Engine: 1986 305 C.I.D. Bored .030 over
Transmission: TH350 W/Shift Kit
Axle/Gears: 3:08
i just drove home ........about halfway home the tube on the back of my mechanical oil pressure gauge popped off(dont know how....its been on for years and still loooks new.......well needless to say molten hot oil began to spray out the tube.....by the time i could grab it a good amount poured onto my cd player and passenger seat.....(luckily my cd case was closed and on the seat so it took most of the abuse instead of my seat........
in the middle of traffic and quick stupid thinking i put my thumb over the tube to stop the flow......big mistake.....that oil was ****ing hot...... but i refused to let go until i pulled over and shut off engine......soas to not have an oil bath
final results.
lost about a quart of oil(no biggie i had a quart in back of car)
cd player covered in oil
cd case ruined
burnt finger(pretty bad too hurts like hell)
center consol covered in oil
ruined shorts......got some on em...wont come out
just had to vent.....off to clean the car now.....ahhhhhhh
btw the gauge was mounted under the center vents......had been there for about two years with no trouble.....still not sure how that compression fitting worked its way loose.........
thanks for lettin me bitch....
Old Jul 23, 2002 | 01:44 PM
Odyssey's Avatar
Why would the tube in the BACK of the manifold spray oil INSIDE your car ?!?!?!?! Did you have some sort of temperature guage inside the car or something ?
Old Jul 23, 2002 | 02:00 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
i was considering putting a mechanical one in but the thought of having that happen to me is what detered me from doing it. I know this doesnt help you but imho the best place for gauges of that sort are on the outside of the car on the cowl area. Best of luck getting it all sorted out, though.
Old Jul 23, 2002 | 02:08 PM
Axle/Gears: 3:08
well i got it cleaned up.....it wasnt too bad since my finger took 80 percent of the abuse.....nice old blister forming too......oh well another lesson learned......
Old Jul 23, 2002 | 03:12 PM
ede's Avatar
ede
bet the line was plastic wasn't it? i've trashed about a mile of the plastic, i always go to the hardwear store and buy copper. i'd bet if i tried i could put a NPT or AN adapter fitting on it and run braided stainless.
Old Jul 23, 2002 | 03:14 PM
Axle/Gears: 3:08
yeah it was a plastic tube....i remember when i installed it i thought....man it would suck if this ruptured or pulled out...now i know........buyer beware.......lol
oil is hot
fingers dont like hot
Old Jul 23, 2002 | 03:23 PM
nitrobreth's Avatar
****, i know how you're feeling. something like that happened in my 89 1/2 ton chevy. only REALLY bad part was, it hit something electrical, lit up like stogie. i lost the whole truck, because i didn't feel like messing with copper.
Old Jul 23, 2002 | 05:16 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Oh frig; I've had a plastic line on my mechanical pressure gauge since '97. I better replace it, eh? Would I use the same compression fittings that came with the plastic hookup kit? Or do I need stronger fittings?
Old Jul 24, 2002 | 06:06 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
In over 30 years, I've never had a plastic line fail. Seep a little, yes, but never fail.
Last spring, when running the '57 through tech at Bandimere, I had a new oil pressure gage, and, you guessed it, a new, bright white plastic line. They made me change it to copper (NHRA requirement). Had it been the old, dirty, oil-stained plastic line, they probably wouldn't have seen it or said anything (like they hadn't since 1995). The copper tubing oil pressure kit cost me $18 at the track parts store.
Tom, plastic and copper use the same fittings.
Old Jul 24, 2002 | 06:46 PM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
Sorry to hear of your accident.
And now we know why we don't put fuel pressure gages in our cars without an isolator. Though I have seen two 4th gen owners with just that set up!
Old Jul 24, 2002 | 08:30 PM
goneracin's Avatar
Autometer, and most of the braided hose makers, make an adapter from the gauge(i believe most are 1/8 or 1/4 pipe) to either #3 or #4 stainless. And the pressure tap in the block is also 1/8 pipe. I wont use anything but stainless hose for the same reason. That, or use the autometer electric gauge. Sorry to hear about your mess dude, that sucks.
Old Jul 24, 2002 | 09:21 PM
EvilCartman's Avatar
Car: '82 Z28
Eh, mechanical gauge inside of car, line runs from the engine to the back of the guage that is inside the car, line breaks loose from gauge inside of car and shoots oil everywhere.... inside the car. That's why I'm going to use electric gauges.
Old Jul 24, 2002 | 09:22 PM
Axle/Gears: 3:08
TRUST ME IT SUCKS ***
Old Jul 24, 2002 | 09:52 PM
rezinn's Avatar
You're lucky. One of my friends had an old jeep with a mechanic guage that was routed above the pedals. It broke and sprayed hot oil all over HIS LEGS in traffic!
Old Jul 25, 2002 | 06:26 AM
ronterry's Avatar
Car: '94 Corvette
Yeap, I took it on the leg also. I have electric Autometer now.
I dig that metaphor molten '83CAMAROMAN' cause that **** IS hot!!!
Ron
Old Jul 25, 2002 | 08:46 AM
Axle/Gears: 3:08
yeah it was def a lesson learned........one bright side....oil maked a black interior shine up real nice
Hotrodboba400
Dec 10, 2019 07:07 PM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
Amillionoh7
Sep 5, 2015 11:44 PM
Vassago
Convertibles
Sep 4, 2015 09:37 PM
mrdevontay
Sep 2, 2015 08:04 PM
