Car ishard to start when cold- why?
Old Jul 25, 2002 | 06:01 AM
The Josh's Avatar
Ok, two weeks ago, I changed the spark plugs, cap & rotor, and wires. I installed an MSD coil as well. I sprayed carb cleaner into the TPI plenum and throttle body to clean them out; good and clean.
But, it is hard to start when cold. Any ideas? When it fires it runs smooth and well. So i know the fuel injectors are ok...
1992 350TPI. I am baffled!
Any help is appreciated. Thanks in advance...
The Josh
Old Jul 25, 2002 | 08:29 AM
ATOMonkey's Avatar
Has it always done this, or is this a new symptom? When you say hard to start, is that just a long crank to start, or is it actually spinning slow? Does it just hit a couple of cylinders and then start? Please be more specific. It could still be dirty injectors. I wouldn't rule that out because it idles well. The continuous adjustment by the computer helps that out. The higher air velocity also helps atomizations as compared to cranking speed.
Old Jul 25, 2002 | 08:41 AM
Vader's Avatar
j,
How accurate is your CTS?
midge54
Dec 27, 2019 04:14 PM
Wade787b
Sep 29, 2015 01:15 PM
killer777
Aug 8, 2015 02:47 PM
L98GTA87
Aug 5, 2015 11:02 PM
