loud pete jackson gear drive, o yeah baby
Old Jul 27, 2002 | 07:56 PM
nolanr0413's Avatar
Car: Trans am
Does anyone have a sound clip of a pete jackson loud gear drive. I have head the queit one and its pretty cool i just wanna hear the loud one. I have an 85 ta with a 305 tpi , has anyone done one of the on a third gen . And if so how much of a pain in the *** was it too install. Any info is apreciated. And yes i want the annoying sound.
Old Jul 27, 2002 | 08:20 PM
89Irocz23's Avatar
Well I would recommend doing it on a fuel injection car. It will set the knock sensor off and run like ****, but if you have carb car then go for it.
Old Jul 27, 2002 | 08:40 PM
ede's Avatar
ede
it'll work with knock senser ask someone that has one, like madmax
Old Jul 27, 2002 | 09:28 PM
Odyssey's Avatar
I wish this stupid "urban legend" would just go away once and for all...
Old Jul 27, 2002 | 10:52 PM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
I've got one, its EDELBROCK not pete jackson but its the same thing, Ive installed both on difference engine and they are identical, even price-wise. Right now my engine is open headers, so the only thing making noise is my ear-drums yelling at me to shut it off. I also have a blower which should make its own whining noise, but I cant hear that either. Yeah, this thing is loud. getting exhaust monday, should have pics soon too. The sad thing is, the Whine of the gear drive sounds like a blower right? BUt I do have a blower, but my blower is QUIET at idle, so at idle when my gear drive is whining people will be like "hey you have a blower!" But ill say "no! thats not the blower making that noise! its my gear drive!!!!" And they wont beleive me... heh sheesh.
Old Jul 27, 2002 | 11:30 PM
Big454blockchevy's Avatar
Car: 86 z28
Engine: Hyd. roller 498
Axle/Gears: 12 bolt 3.90 gears
I had a gear drive on my 79 Silverado 4x4. At first it drove me crazy but after a while I got used to the noise . It took some time though.
Old Jul 28, 2002 | 02:11 AM
bhaas's Avatar
I have the Pete Jackson geardrive. I had it in my car for about a year. I couldn't stand it. It's for sale. $75 +s/h and it's yours. Easy to install. Much easier than a timing chain. My chain gave me hell. If your interested E-mail me. bhaas@bigfoot.com
Brad...
Old Jul 28, 2002 | 06:21 PM
nolanr0413's Avatar
Car: Trans am
why do you think it would set off the knock censor. For all the car knows is that the timing chain is still their, its still getting the job done.i dont understand.
Old Jul 28, 2002 | 06:27 PM
bhaas's Avatar
From the vibration it creates.
Old Jul 28, 2002 | 06:42 PM
Kingtal0n's Avatar
Transmission: 4l80e
Axle/Gears: 3.512
Ok, you know, lets address this issue... Its not vibration, this particular gear drive uses a floating idler gear, which effectivelly MOVES and CUSHIONS and WOBBLES and JOUNCES, BOUNCES, SLIPS and Slides around to ABSORB all the nasty "vibrations".... HOWEVER, there is the issue of a "Solid" Connection between the crank and the cam, which, unlike a timing chain, does NOT allow for "play" (every .030" of Chain Stretch Retards Cam Timing 2* 0 If i remember correctly) in THAT respect... The result? Not Vibrations... but we do have a "rigidity" that negativelly impacts one thing: Distributor Gear. Using a Gear Drive is like using a Roller cam... Its so rigid it can cause spark scatter or pre-mature camshaft wear if you dont use a Bronze Gear instead of the iron one... Bronze is much softer and absorbs that nasty "rigidity". There is some "Speculation" of how a Gear drive would also Increase Valve Train wear because of this rigidness... especially in a Solid Lifter Application.. but NOTHING is proven to this respect... its all Idle Speculation.
jklein337
Sep 19, 2018 06:23 PM
Andrew6.688
Dec 13, 2015 10:59 AM
db057
Aug 22, 2015 08:17 PM
gta power
Aug 13, 2015 06:15 AM
