is there diff between engine??
Old Jul 28, 2002 | 12:46 AM
muffler's Avatar
some buddy of mine is givin me a 305 to put in my v6. he actually has 2 one from a 82 the other from a 86. is there a difference between them or are they an lg4 and are they good
pse help. its free so why not is my answer but i also dont want crap
:nono:
Old Jul 28, 2002 | 12:45 PM
iroc22's Avatar
They're pretty much the same engine, except I would take the 86 305 because it has flat top pistons. The 82 will have dished ones, lower the compression ratio.
Old Jul 28, 2002 | 02:16 PM
firechicken_3's Avatar
Car: 1984 Firebird
Engine: 350 Terminator EFI
Axle/Gears: 4.10
82= 2 piece rear main
86= 1 piece rear main,
i second the movement for the 86 due to compression, and the fact that if you ever decide to put a 6 spd from a 4th gen in flywheels are much easier to come by and lots cheaper
wouldn't the 86 also be a roller cam????,
Old Jul 28, 2002 | 09:29 PM
iroc22's Avatar
Excellent point about the seals. I missed that one. The 1 piece rear seal is less prone to leaks also, but you will have to get a different flexplate/flywheel for it, but it is very easy to obtain.
Actually 87 was the first year of the roller camshaft.
Old Jul 28, 2002 | 11:01 PM
muffler's Avatar
tks for the help
another question is the tranny the same for both.
i have about 1k to spend on it and dont realy know what to do first. rebuild or fix it. any info would be great
Old Jul 28, 2002 | 11:25 PM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
I thought the 86s still had two piece rear seals
Choose the 86--it has about 20 more hp
Old Jul 29, 2002 | 12:08 PM
iroc22's Avatar
Originally posted by muffler
tks for the help
The tranny is the same for both. You will just need a different flexplate (auto) or flywheel (manual) so it will bolt up. You could get one from any junkyard.
Sitting Bull, 86 was the first year of the 1 piece rear seal.
Old Jul 29, 2002 | 12:42 PM
Engine: 305-4v
That's alright with me, seeing as I have an 86
Old Jul 29, 2002 | 01:56 PM
ATOMonkey's Avatar
Torque converters are different for the two. 27 spline '82 30 spline '86. Parts are cheaper for two piece seal engines. Did they start that center bolt valve cover stuff in '86 too? Probably doesn't matter seeing how he should throw away everything but the block anyway.
Old Jul 29, 2002 | 03:16 PM
iroc22's Avatar
No 87 was the first year of the centerbolt heads on SBC's.
Why should he throw away the heads? If he's on a budget, the 416 castings can be made into excellent heads.
Old Jul 30, 2002 | 10:13 AM
ATOMonkey's Avatar
That's why I was looking at it from a cost stand point. If he does the machining himself, then you're right it's going to be cheaper to keep them. There are plenty of aftermarket and stock replacement and slightly used heads that will go for the same or less than machining at some shops. I didn't mean to imply throw them away right now. Just when he wants to start making power.
Reddeath210
Oct 6, 2015 08:20 AM
draco
Oct 4, 2015 09:25 PM
E Rod
Aug 28, 2015 05:17 AM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
