Sunpro oil pressure guage reads as low as 15 at idle, and 50-60 at cruise.......wtF?
Old Jul 28, 2002 | 06:51 AM
ChrisFormula355's Avatar
Car: Junk
Engine: Junk with nitrous
Transmission: Junk with gears
Oil pump was fairly new (had a couple thousand miles on it) and I just installed a new oil pressure guage....... a 2inch supro mechanical, and it goes as low as 15 or LESS after the motor is warmed up............WTF??? The weird thing is even after its warmed up when I cruise around at 3K rpms the pressure is up around 50-60, doesn't make much sense, could it just be the guage? How accurate are those $10 units.
Old Jul 28, 2002 | 07:05 AM
PF Flyer's Avatar
Car: 87 T/A
Engine: TPI 350 ci
Transmission: 5 speed
I don't know about what it should read ...
... but my stock one read more than that at idle.
'course that was before it froze up on me at the track (road racing) and I lost all oil pressure.
I've just pulled the engine and after removing the pan found a few metal pieces that used to be the input shaft. After removing it and trying to turn it and it's froze. Now the )internal) cleanup begins and maybe a Melling pump.
Mike
Attached Thumbnails Sunpro oil pressure guage reads  as low as 15 at idle, and 50-60 at cruise.......wtF?-p6220463-copy.jpg
Old Jul 28, 2002 | 10:49 AM
evil t/a's Avatar
Re: Sunpro oil pressure guage reads as low as 15 at idle, and 50-60 at cruise.......wtF?
You only need 10 psi per 1000rpm so if that what you are worried about you are fine.
Old Jul 28, 2002 | 01:00 PM
nightstar's Avatar
according to my owner's manual, normal pressure is between 20 (or is it 15?) and 60 psi
and i read (stock gauge) ~15-20psi at idle (usually towards 15 if i'm a little low on oil) and anywhere from 45-60 at any moving speed.
Old Jul 28, 2002 | 02:59 PM
chevymad's Avatar
Car: 87 Formula
Engine: 327
You're gauge sounds accurate. If it scares you too much you might try changing either brands or weight of oil. I've found different brands will affect hot idle oil pressure quite a bit. With valvoline dino oil I had 20psi hot. Quaker state got me 25. Now with 15w50 mobil 1 synth I have 40 at idle and 70 at cruise. I'm not running a high volume pump either. Somebody already mentioned you only need 10psi per 1000rpm. But I too like to see more than 15psi.
Another plus to the mobil 1, the dreaded Comp clatter is quieter now. And the oil pressure is much more stable at all times. Very little fluctuation.
Old Jul 28, 2002 | 07:14 PM
boogie's Avatar
You wouldn't happen to have the M55A melling high pressure pump, they operate like that.
Lonnie
Old Jul 29, 2002 | 11:18 AM
Car: Junk
Ok well then i'm going to try that mobil 1 synthetic stuff.............as much as it may cost because it really does bug me to see the guage dip to almost nothing at idle. It was a stock replacement pump, not sure what the part # was.
Old Jun 17, 2006 | 06:48 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
Can anyone elaborate on the M55A pump? I'm experiencing 10 PSI at idle (Supertech HD-30) and a very good 40+ with RPM's and am using that pump. I'm worried I've got something else going on.
Old Jun 18, 2006 | 12:30 AM
92centexcamaro's Avatar
Car: 92 Camaro RS
Transmission: stock
Axle/Gears: stock
Im having the same problem except my guage is stock. I have a pretty bad oil.. erm purge i would say... its leaking from the intake and valve covers(i have the gasgets to change them out just havent had the time yet) I use 10w30 oil in her... I think I will change it out soon and use some 10w50 or 15w50 and see if that helps? whado you experts think?
89GTAOz
May 16, 2020 09:31 AM
db057
Aug 22, 2015 08:17 PM
Navy8125
Aug 21, 2015 09:32 AM
bamaboy0323
Aug 15, 2015 07:20 AM
ChevyZ71
Aug 13, 2015 07:30 AM
