Will a Code 24 (VSS) affect performance or driveability?
Old Aug 1, 2002 | 03:03 AM
84L69TA's Avatar
Car: 4 Mopars total
Engine: Pentastar power
Transmission: T/F and New Process
Axle/Gears: Three 8 3/4's & one 9 1/4
Im running around without a working speedo right now...cause I did a auto-to-5 speed swap a couple weeks ago and the trans is out of a 91 Formula and my car is in 83 T/A. As im sure all of you know...the 83 is a cable speedo and the 91 is electronic. And the adapters in the trans arent even close to being the same size so swap them. On the plus side, my 86 S10 looks to have the same size at the 91 trans, so Ill try to stick one of those in there. Anyway, the only code it is showing is a code 24....which translates to an inoperable or malfunctioning VSS. Will this affect performance, or fuel mileage in any way? Please let me know as I am very curious to know if this is doing anything. Thanks all
Old Aug 1, 2002 | 08:41 PM
MikeZ28's Avatar
Car: 92 Z28 Z03
Transmission: 700-R4
Axle/Gears: 2.73 G80
I have driven with a code 24 for 3 years and do not have one problem with the car. Everthing is the same as it was before the speedo was broke.
Old Aug 1, 2002 | 08:55 PM
jasonbennett's Avatar
When my 92's vss went out, it threw codes and cut down the power. Mine was an auto and it also kicked it out of 4th until i got it fixed, but i don't think the older computers do that.
Old Aug 1, 2002 | 09:27 PM
BOTTLEDZ28's Avatar
Transmission: A4
note to self... never buy a car from mikeZ28.
Old Aug 2, 2002 | 06:10 PM
MikeZ28's Avatar
Car: 92 Z28 Z03
why you sayin that BOTTLEDZr28, im to lazy to get it fixed. is it that big of a deal? i tell how fast im going by the tach. are you sayin there isn't one thing wrong with ur car? i bet ur t-tops leak oh i forgot 91's don't have t-tops
GTAman
Jul 3, 2024 07:29 PM
BumpaD82
Feb 26, 2016 02:57 PM
64Chief
Sep 12, 2015 08:05 AM
64goatman
Sep 9, 2015 01:09 PM
lakeffect2
Sep 7, 2015 03:52 PM
