Whats a good place to get a chip...(PROM)?
Old Aug 1, 2002 | 03:08 AM
84L69TA's Avatar
Car: 4 Mopars total
Engine: Pentastar power
Transmission: T/F and New Process
Axle/Gears: Three 8 3/4's & one 9 1/4
I swapped my 83 Trans Am from an auto to a 5-speed a couple weeks ago. My question is...GM discontinued the PROMs for this particular application, and I need to put a 5-speed PROM in it. Are there and companies out there that offer chips for these early thirdgens? Its a 305 carb car. I want to correct my high idle problem and make it run like an original stick car. Also, I was told that in my case....the computer could go into "limp mode" or "fail safe" mode and performance and mileage will suffer unless I change the chip. But please let me know. THX
Old Aug 1, 2002 | 07:29 AM
ede's Avatar
ede
if all you need is a stock replacement look in the junk yard or ask on here for one. if you're wanting preformance visit the prom board and learn to burn your own.
Old Aug 1, 2002 | 03:07 PM
88ROC1LE's Avatar
:nono: Burn your own!!!!
Old Aug 1, 2002 | 09:09 PM
84L69TA's Avatar
Car: 4 Mopars total
That sounds like a good idea..but I dont have the equipment or the knowledge reqired to do that. But Ill ask around on the board for one...and ill look into burning. THX
Old Aug 2, 2002 | 07:15 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
For a carb car, it's next to impossible to burn one... they're not the same as FI You'll have to get a junkyard one, or get one from Hypertech (I think they're the only ones that still make one for that setup though I could be wrong)
Steven 86IROC-Z
May 24, 2026 04:52 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Sanjay
Aug 12, 2015 03:41 PM
djmarch
Aug 11, 2015 10:22 AM
the_nikfive
Aug 11, 2015 02:46 AM
