timming chain cover, help
Old Aug 1, 2002 | 06:45 PM
89formula#1's Avatar
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
ok guys i have a 305 tbi in my 89 bird and it has a 6inch balencer and i am puttin in a 350 that wiill have an 8 inch balancer and i don't have a timming cover that has the timming pointer in the middle of the cover so i can see it cause rigth now i have a chome cover with the pointewr thats off to the side but i realized when i put the power steering pump on its gonna be blocked witch means do timming light. so does anyone know where i can buy a timming cover for an 8in balencer with the pointer on the middle of the cover??i am stumped here and the engine is ready to go in
Old Aug 2, 2002 | 10:53 AM
Vader's Avatar
Most of the aftermarket timing tabs I've seen are similar to the factory tab on the left side of the engine.
Old Aug 2, 2002 | 11:43 AM
ATOMonkey's Avatar
Get some degreed balancer tape and make your own timing reference marker.
Old Aug 2, 2002 | 01:04 PM
Car: 89 Formula
Engine: Carbed 5.7
yes i know that the after market tabs are to the laeft cause i have one and i also have the tape. but wut i was asking was where can i buy a cover with the tab in the center because with the one to the left it is covered by the powersteering pump and and u can't use a timming gun.
Old Aug 2, 2002 | 02:49 PM
AdmiralNahohkta's Avatar
Car: GTO
Engine: GM 350HO, 4.6 Overhead cam, 413 Wed
Are you sure?
I just did a 305 to 350HO swap in my '89 Bird and used an adjustible Mr. Gasket pointer for an 8" balancer. I can still see to adjust timing, I just have to look in at a different angle. I couldn't find ANYONE who made a cover with a integral central timing tab.
Old Aug 2, 2002 | 04:15 PM
Car: 89 Formula
Engine: Carbed 5.7
now can u get a timming light on it or no??
Old Aug 3, 2002 | 12:14 AM
Car: GTO
No problem. I stand over the left fender and look just over the power steering pump and under the water pump. I have a good view of the timing tab and about 1/4 of the balancer.
db057
Apr 28, 2019 07:45 AM
1Aauto
Sponsored Vendors
Oct 5, 2015 03:14 PM
timonator
Sep 17, 2015 06:57 PM
RyanJB
Sep 14, 2015 03:39 PM
SG91camaro
Sep 5, 2015 10:27 PM
