Car running hot
Old Aug 2, 2002 | 02:37 AM
Nathan Staab's Avatar
Car running hot
Hey guys - i have a newly rebuilt 383, forged pistons - with a vortech s-trim@10psi, the cooling system is a stewart water pump, and a fluidyne 2 core aluminum radiator. My problem is the goddamn car still runs hotter than it should (240ish, no AC..), any ideas? any help would be greatly appreciated as this issue is driving me crazy.
Old Aug 2, 2002 | 03:43 AM
rezinn's Avatar
More info please. When does it run this hot? What mixture coolant/water are you using? What stat? What kind of fans? What kind of quality is that radiator?
Old Aug 2, 2002 | 11:30 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Yup. Need mo info.
Is your front skirt (air deflector) for the radiator still connected?
Old Aug 2, 2002 | 06:10 PM
Its a fluidyne 2 core aluminum - Yes, the front air deflector is still there, im going to end up getting a new one cause the old one is semi flexible. I found the cooling issue though - bad relay.. grr. she is now running happily at 220. the next issue is a gremlin that keeps toasting TFI coils.
Old Aug 3, 2002 | 12:11 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
wow 220?
If the stock temp gauge can be trusted i run 184 as long as i'm moving. i have a new 195 stat in my car.
Old Aug 3, 2002 | 12:45 PM
yeah.. this is in 113 degree heat, at night when its about 90 out - im running about 184-190.. (or so the stock guage says)
theshackle
Mar 5, 2017 06:37 PM
TheExaminer
Aug 26, 2015 04:59 PM
kyleb24
Aug 15, 2015 08:24 AM
Kaweh
Aug 9, 2015 02:54 PM
