Carbon Buildup
Old Aug 3, 2002 | 06:04 PM
REBIRTH's Avatar
Carbon Buildup
Ok, a while back, I replaced the Valve Cover Gaskets due to a small leak. I noticed that there was a carbon buildup.
I have been using 92 octane Texaco gas, so it's not a fuel grade problem.
Can anyone help me out?
Old Aug 3, 2002 | 06:05 PM
REBIRTH's Avatar
Build up under the Valve Covers. Forgot that part.
Old Aug 4, 2002 | 09:19 AM
WideOpenVTwin's Avatar
Car: 1992 Camaro RS
Engine: 355
Axle/Gears: 3.73:1
Your right, definatly not a fuel problem. Oil buildup usually comes from not changing the oil enough. All engine as they age will experiance some buildup, but if the entire head, rockers, valve cover has a thick layer of buildup then that is negligance. If you think it is real bad, change your oil often for a few times, like at 1500 miles, it will help clean up your engine.
Old Aug 4, 2002 | 10:57 AM
GTA88's Avatar
Make sure the PCV valve is not clogged.
Old Aug 4, 2002 | 11:26 AM
REBIRTH's Avatar
Thanks for the replies.
I am going to do both. My dad told me he changed the oil before he gave it to me....come to find out he didn't.
Miscommunication, I hate it.
Old Aug 5, 2002 | 02:41 AM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
you may want to consider changing to synthetic....it will help to clean up the system.
Old Aug 5, 2002 | 08:48 AM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
don't really know if it works or not but I know a lot of rotory guys let the inside of the motor sit in the stuff overnight to help get rid of carbon
and that is using either ATF or marval mystery oil
I know when for sheits and giggs I put the MMO in my oil on time on a fresh oil change the oil turned black really quick. not sure if the stuff was just making my oil change colors though or if it was getting rid of all the crud that was in my oiling system
also just as a side night with the 92 octane
try switching to a lower grade gas
you might get better milage and power if you do
the higher octane stuff burns slower and so if still might be burning outside the exhuast port just wasting that energy where a low octane fuel would better be able to use up more of it energy pushing the piston down
though if you have higher compression or adv your timing you might need the high octane stuff then
just saying worth a shot
grngryoutmyway
Oct 18, 2016 05:48 PM
CrazyHawaiian
Aftermarket Product Review
Jun 23, 2001 07:30 AM
91RedBigFinZ
Mar 14, 2001 11:38 PM
Jess Cooper
Jul 24, 2000 01:31 AM
