HELP!!!! Knocking and Banging from right rear side
Old Aug 4, 2002 | 10:16 AM
Formula305FI's Avatar
Car: 96 SS, 88 IROC
Engine: Lt1, TPI
Transmission: m6,a4
Axle/Gears: 3.90. 3.73
Ok I just spent around 500.00$ in exhaust work, and now I dont know if its the exhaust, or the right rear wheel bearings, brake shoes, axel or what!?!?! It makes like a knocking/banging sound when I turn left only, and go over bumps, but not all bumps... All and any help would be great THANK YOU....
Old Aug 4, 2002 | 10:54 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
start moving things around by hand (exhaust) and see if you can make anything knock
Old Aug 4, 2002 | 11:04 AM
Car: 96 SS, 88 IROC
Engine: Lt1, TPI
Transmission: m6,a4
moved what i could by hand muffler s pipe, rocked the car up and down, no noises everything seemed tighteD?????
Old Aug 4, 2002 | 06:33 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
take a look at the upper shock mount, see if it's broken out of the rest of the sheet metal like always happens to these cars
Old Aug 4, 2002 | 09:57 PM
Car: 96 SS, 88 IROC
Engine: Lt1, TPI
Transmission: m6,a4
well wouldnt that of made a noise when i was rocking the car?
Old Aug 4, 2002 | 11:17 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I don't know.... have you looked at it?
Old Aug 5, 2002 | 12:53 AM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
Check the rubber bushings at the ends of the lower control arms, panhard rod, and struts. Also check to make sure the bumpstops are still there on both sides. They're right above the axle, next to the wheel. On my POS formula, the bumpstop on the passenger side had rotted off, and every time I hit a big bump, or made a hard left, I got a really loud thump sound. But then again, my formula was lowered a lot. A LOT.
Old Aug 5, 2002 | 01:55 AM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
Make sure your jack and spare tire are not banging around in there(right side,rear panel)..and yes . I am serious!
mustangman65_79
Apr 14, 2017 05:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
db057
Aug 22, 2015 08:17 PM
BlackBoulder
Aug 11, 2015 11:15 PM
gwade12
Aug 8, 2015 08:17 AM
