Need to check Cams lift, how do I do this?(its out of the car)
Old Aug 4, 2002 | 06:21 PM
JucinGTA's Avatar
K I bought a used cam which we are thinking it might be whiped, is there an equation that I can use to figure it out with a mic?
Old Aug 4, 2002 | 06:30 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
No equation; but measure the narrowest width of each intake and exhaust lobe, and the largest "height" of each, and see if all 8 intakes and all 8 exhausts measure the same.... if not, put it in the trash
Old Aug 4, 2002 | 07:17 PM
92Z's Avatar
92Z
Measure the largest "height" of the lobe, and subtract the narrowest "width" (this is the "base circle") of the lobe, then times that by your rocker ratio to get lift. Ex: 1.55 "height" - 1.17
"narrowest" (or "base circle") = .380 x 1.5 rocker ratio = .570 lift.
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
camaro71633
Sep 1, 2015 10:24 AM
Fronzizzle
Aug 9, 2015 01:15 PM
anesthes
Aug 8, 2015 09:37 PM
