Question about Distributor
Old Aug 5, 2002 | 04:43 PM
super83Z's Avatar
Car: 1983 Z28
Engine: 6.6L 406
I would like to get a distributor the size of the later style thirdgen ones. BUt I need it to have vacuum advance. Can I convert a electronic one to vacuum? Or is there someone that makes one that is the small style but vacuum advance? Or am I stuck with the huge HEI one? thanks
Shawn
Old Aug 5, 2002 | 05:13 PM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
The Later Third gen style distributor is computer-controlled.
That's why it doesn't have a vacuum advance....it doesn't have any centrifical advance either. If your F-body isn't computer controlled, any of the aftermarket distributors for chevy should work. The MSD ready-to-run model doesn't require any external controller, has a vacuum advance and a smaller cap.
The Pro-Billet Ready-To-Run is part#8360 and is $246.95 at Summit.
http://store.summitracing.com/defaul...rchType%3DBoth
-Rich-
Old Aug 5, 2002 | 05:32 PM
super83Z's Avatar
Car: 1983 Z28
Engine: 6.6L 406
Yeah I thought that one might work I was hoping to find one a little cheaper. Is there anyway to convert a computer controlled one to a vacuum advance one?
Old Aug 5, 2002 | 08:53 PM
jfox55's Avatar
Unless I am wrong, I believe you have to get rid of your computer. Or else, your computer will control this. THere is a thread in the carb board. It is the sticky, that stays at the top of the page. A whole page in there about computer controlled and non computer controlled. Hope this helps
Old Aug 5, 2002 | 09:09 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I got my Accel one for about $160-$180 forget which.
Old Aug 5, 2002 | 10:44 PM
super83Z's Avatar
Car: 1983 Z28
Engine: 6.6L 406
Mark do you have an HEI distributo or do you have the later year smaller distributor.
I know what I have to do withj my computer I was wondering if anyone made a vacuum advance distributor in the smaller version.
Frozer!!!
Jan 19, 2024 04:55 PM
Caspar
Jun 19, 2016 11:19 PM
beastin91rs
Oct 9, 2015 07:38 AM
86IROC112
Aug 17, 2015 07:57 PM
redmaroz
Aug 16, 2015 11:40 PM
