What do I disconnect to set timing on my '83 Z28?
Old Aug 6, 2002 | 03:58 PM
clemsparks's Avatar
Car: 1983 Z28
Transmission: WCT5
Just wondering. Don't I need to disconnect something on the distributor to properly remove the computer control from the circuit when setting the timing?
if so, which connector? the flat 4 wire one? or something else?
Thanks,
Clem
Old Aug 6, 2002 | 04:04 PM
InTeRcEpToR5.7l's Avatar
its slipping my mind, but the short wire that runs to the thing in front of the distributor cap....there are two wires hooked to it, unhook the one with the brown wires, it disconnects the computer so it wont advance or retard the timing when ur trying to set it
Old Aug 6, 2002 | 04:09 PM
flyway190's Avatar
I'm pretty sure that on your car it's the 4-wire connector going into the back of the distributor. I think the connector is different on later models.
Old Aug 6, 2002 | 04:19 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Right, it's the 4-wire Weatherpack that hangs down off the back of the dist.
Ghettobird52
Jul 5, 2024 11:18 PM
Frozer!!!
Jan 19, 2024 04:55 PM
specialized
Jun 18, 2022 09:26 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
TheExaminer
Aug 26, 2015 04:59 PM
