MAF burnoff relay
Old Aug 8, 2002 | 03:36 PM
ytry's Avatar
MAF burnoff relay
Does anybody know where this is? Iwas told by the dealer it was on the firewall on the outside of the booster but there is two relays with the same part number. If anyone has replaced one please let me know which one it is. THANK YOU
Old Aug 8, 2002 | 04:36 PM
rezinn's Avatar
I think the MAF power and burnoff relays look the same, with the fuel pump relay being attached to the firewall differently in between them. On my car the burnoff relay is closest to the brake booster.
Old Aug 10, 2002 | 11:58 PM
89formula#1's Avatar
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
hey guys wut is maf?? woudlk u need it if u didn;t have a computer?
Old Aug 11, 2002 | 12:54 AM
@ZZKKER's Avatar
Car: 86 iroc, 87 iroc, 89 iroc, 89 formula, 84 supra, 85 trans am
Engine: t\a motor 355 lt1 intake, t56,the works, 89 roc 427 sbc tt project
Transmission: to many to list
Axle/Gears: 9bolt 4:10 in the T/A
the relays are common gm style and are interchangeable, as for the maf no comp=no maf
thanks
anthony
Old Aug 11, 2002 | 09:58 AM
Vader's Avatar
Old Aug 14, 2002 | 08:59 PM
@ZZKKER's Avatar
you need to double check to make sure that your relays are in the same order because a couple of the conectors use the same relay, and the relays may not have come from factory in the order of the ones in the pic.
thanks
anthony
Old Aug 17, 2002 | 04:51 PM
ytry's Avatar
I think the dealer gave me the power relay, because it is the same part number as the two right relays but the left relay is a different relay.
Mark_ZZ3
May 24, 2018 01:02 PM
thunder57
Nov 7, 2015 02:28 PM
racereese
Oct 3, 2015 03:46 PM
