need help on vortec heads
Old Aug 9, 2002 | 12:10 AM
PerfectionGoku's Avatar
Car: 98 Camaro Z28
Hi i need help with my 87 GTA 5.7. I plan on getting vortec heads and putting them on my GTA its a Stock TPI 350. I need to know what i need to put them in? To run correctly, I have Edelbrock headers, will they bolt up correctly? And what else is need to make everything work right and help would be great.Thanks
Old Aug 9, 2002 | 12:31 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Youll need a different tpi intake base. scoggin-dickey, umong others, sells em. Thers also a whole bunch of other issues to be delt with when you get a cam. The pressed in studs will give problems, do a search on the boards.
Old Aug 9, 2002 | 12:34 AM
Car: 98 Camaro Z28
can i use the stock cam
i just want to slap on some vortec heads and the vortec intake.
Old Aug 9, 2002 | 12:39 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Wouldn't we all. It's never that simple. Search the boards
for past posts about prepping vortec heads for your motor.
Old Aug 9, 2002 | 01:52 AM
BitchinCamaro's Avatar
If all you want to do is bolt on the head and intake, then you shouldn't have a problem. But if you plan a cam swap in the future, you should look into upgrading the springs. You will need to reloacate your coil, the intake uses a different torque pattern/specs, headers shoudl bolt up fine. The intake will need a couple little things, plugging unused holes and such. Other than that should be a standard head swap.
84z96L31vortec
Aug 20, 2017 12:16 AM
Tinbender59
Mar 17, 2017 10:50 AM
z28guy134
Sep 1, 2015 11:50 PM
earlpote
Aug 28, 2015 10:42 AM
L98GTA87
Aug 11, 2015 06:55 PM
