changed intake now i seem to have an electrical short
Hey guys,
I just switched intake's from an airgap to a stealth. I just finished getting everything back together and now when I go to start the car the little black wire that splits off from the negative battery cable and grounds to the passanger side fender starts to burn up and smoke.
What would cause this??
thanks!,
Ben
thanks!,
Ben
Ah i found it, that 2 wire plug that goes into the alternator was broken inside the plug thing, replaced the wire and it stoped smoking, now if it would only start! agh! I can't figure it out. I took the timing to tdc on the #1 plug and it just keeps cranking... everynow and then the carb will spit some gas up but it dosn't turn over at all. =[ any ideas?
Terrell351
Jun 13, 2021 01:13 PM
86IROC112
Aug 17, 2015 02:00 PM
db057
Aug 11, 2015 10:11 PM
