TPI intake manifold
Old Aug 12, 2002 | 08:23 AM
felo72's Avatar
TPI intake manifold
Does anyone know where I could get replacement bolts for my TPI. I don't know if I could use standard ARP small Chevy intake bolts or not. It's and 86 TPI set up on a 1980 block. Any suggestions would be appreciated.
Old Aug 12, 2002 | 10:33 AM
redbird_400's Avatar
Car: 89 Formula Firebird
Engine: 305 - Demon 525
parts store?
Old Aug 12, 2002 | 07:46 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
Check EBAY for some pretty cool looking stainless steel sets.
Old Aug 12, 2002 | 08:32 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
I just used a set of regular ARP intake bolts for a SBC. A couple of corners had sunk threads in the heads so i used the longer stock corner bolts.
Don't forget teflon thread paste on all the bolts into the lifter valley to keep oil off teh intake.
Old Aug 12, 2002 | 08:43 PM
rezinn's Avatar
Don't use the bolts you get at a parts store and DO NOT USE THOSE STAINLESS STEEL SETS FROM EBAY!!!! THEY ARE COMPLETE ****! You need to get the right length bolts with strong hex tops. I made the mistake of using those stainless steel pieces of crap and I had to drill them out of the heads because they can't take the correct torque. Then I used some intake bolt kit that I bought, but the bolts were too short so I ended up helicoiling my heads.
Old Aug 13, 2002 | 07:39 AM
felo72's Avatar
Thanks for all the help guys, I'll go with the ARP intake bolt set. I just wanted to get away from that Torx BS if you know what I mean.
theurge
Aug 21, 2015 12:46 PM
86IROC112
Aug 17, 2015 02:00 PM
st.evel07
Aug 13, 2015 06:15 PM
Jake_92RS
Aug 11, 2015 10:39 AM
