primeing oil pump, big prob i think
Old Aug 12, 2002 | 01:46 PM
89formula#1's Avatar
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
ok guys i finished my 350 and i put oil in it and got everything together and stuff and i went to prime the pump and it says go clockwise so i did but it makes liek a clunking sound and my drill can barely turn it, it actually started smokin. now is there somtin wrong with this pump cause i'd rather fix it now rather then after the egine is in. please any1 who has ever primed a car help thanks guys. ps, how did u pump up your lifters? i poured all 5 quarts in last night threw the pushrod holes to get oil in them but i can still push the rod down a little. thanks
Old Aug 12, 2002 | 02:07 PM
SLOW5.0's Avatar
On the oil pump thing I never had mine smoke before Hummmm might have a problem. The lifters I set in a bucket and sumerge them in oil and let sit for a few days.
Old Aug 12, 2002 | 02:16 PM
Car: 89 Formula
Engine: Carbed 5.7
when u primed dide the pump make any type of knock or chadder or sumtin?
Old Aug 12, 2002 | 02:19 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It takes ALOT of power to turn the oil pump... I've known a couple of people to fry drills doing that, especially the little Black & Decker ¼" ones and similar weenie things...
I wouldn't worry about it.
I don't bother priming motors any more, since about the 30th or 40th one I built... doesn't really seem to do any particular good. No harm of course, but no good either. If the motor is properly built with the correct assembly lube on everything, lifters soaked, etc., there will be plenty of time for the pump to do its job once the engine starts the first time.
Old Aug 12, 2002 | 06:58 PM
1986redbird's Avatar
i have always heard that just soaking the lifter won't do the job, you must submerge the lifters in oil and the use a pushrod to actually pump the lifters a few times while submerged, this will help get the air out and the oil in. I have heard of too many people soaking the lifters and then installing them and when adjusting the rockers actually bottom out the lifters.
Old Aug 12, 2002 | 08:11 PM
ede's Avatar
ede
don't worry about it you don't need to prime the engine before you fire it and you don't need to fill the lifters with oil. it'll all be taken care of as soon as or even before the engien fires. you used assembly lube right? then you shouldn't have any problems.
Old Aug 12, 2002 | 09:37 PM
Car: 89 Formula
Engine: Carbed 5.7
ok well i put the engine and trans in tonight cause oil did eventually srip out of thew rockers. my dad said to adjust thge rockers with a feeler guage and prime it then turn the crank a few times and i did and they pumped rigt up. he also said even if they aren;t pump all the way up u are usin a feeler guage so it doesn;t matter and when they do pump up it will be fine. i duno but they are greta now and the engine looks awsome sittin in the bay. thanks for all your help oh and ede yeas i did use assembly lube and lots of it lol
toronto formula
Nov 10, 2015 06:17 AM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
xxx3man`
Sep 23, 2015 10:37 PM
Navy8125
Aug 21, 2015 09:32 AM
