engine installation questions
Old Aug 13, 2002 | 12:44 AM
Psyte's Avatar
Car: 1989 Trans Am GTA
Engine: 5.7L 600cfm carb
Transmission: 700R4 (auto)
hi, im about to install a new rebuilt engine.... i have a few quick questions.... when im bolting it up to the transmission, do i need some kind of gasket? or is it just straight metal on metal? the torque converter seems to slide around, is this normal? lots of transmission fluid leaked out of it some how, is it gona leak again when i bolt it up to the fly wheel? or will it some how seal itself? i have an 89 trans am GTA 5.7L i also have a few more questions about converting from TPI to carb. yes i have read the tech article about it. what is the best/cheapest route to go with the fuel pump? mine is an in-tank fuel pump, and i dont know what i should do with it.... its gona be a real bitch to remove it, so is it better to just get a fuel pressure regulator and wire up the old pump some how? and ideas would be greatly appreciated... thanks.
Old Aug 13, 2002 | 07:03 AM
ede's Avatar
ede
no gasket, the TC is bolted to the flex plate, it doesn't move any. grease the outter part of the TC where it contacts the fronyt pump seal in the trans to keep from burning up the seal before it has a chance to get oil on it. run a mechanical and leave the eletric alone and unhooked.
Old Aug 13, 2002 | 07:41 PM
Psyte's Avatar
ok, do you mean, a mechanical fuel pump? if so, how do i leave the electric one unpluged? doesnt it have to be pumping gas out? shouldnt i just replace the whole fuel pump with a new one?
Old Aug 14, 2002 | 08:16 PM
Psyte's Avatar
oppinions anyone?
if anyone here has an oppinion they want to throw in, feel free to do so. how can i install a mechanical pump? or how can i rig up my old pump to work good with a regulator?
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
