Smog Pump
Old Aug 15, 2002 | 09:28 AM
BillD91RS's Avatar
Smog Pump
Is this the smog pump? What does it do and what effect would disconnecting it have on the engine and computer?
Bill
Old Aug 15, 2002 | 10:07 AM
Dragula's Avatar
That be it!!!!!
All it does is inject air into the exhaust providing oxygen so the catalytic convertor can "burn off" the remaining gases.
If you take it off, it will not effect your car at all. The computer will not even know the difference. However, once the air supply is gone to the cat, it will clog up. If you remove the air pump, you need to remove the cat (or simply gut it out).
Without the cat and air pump, you will see a mild increase in performance and exhaust note.
Old Aug 15, 2002 | 10:17 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Uh.........
was something changed? on my car that pulley is the ps pump. i don't see a smog pump on your engine. on mine it was below the ac compressor.
mine's a 92 L98
Old Aug 15, 2002 | 11:33 AM
BillD91RS's Avatar
That picture is actually the one from the Tech article on how to reroute the belt without a smog pump
Old Aug 15, 2002 | 11:39 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Okay. So then you know that's not the smog pump.
Old Aug 15, 2002 | 12:17 PM
Dragula's Avatar
Oh man.....I really screwed the pooch on that one. That is the Power steering pump.
The smog pump is on the lower passenger side........
I forgot that when they went to the serpentine belt it was only the top stuff (AC compressor and alternator) that switched sides.
Damn........I'm getting pathetic in my old age!
You can't miss the smog pump......it has an air hose coming out of the back. Anyways......everything else still pertains.
SORRY:hail: Begging for forgiveness from the Camaro Gods!
italiano67
Dec 11, 2016 09:21 AM
J.C. Denton
Aug 31, 2015 03:11 AM
Victor6
Aug 30, 2015 02:09 AM
camaro_rs350
Northern California
Aug 18, 2015 12:38 AM
mustangman65_79
Aug 7, 2015 09:55 PM
