Removing AC.. What comes out?
Old Aug 17, 2002 | 02:36 PM
bzznczzn's Avatar
I want to pull out my AC system in my car, what needs to come out? I know tha pump needs to come out, but I'd like to clear more space in the engine bay. What other components can be taken out along with the pump?
Any help would be appreciated....
Old Aug 17, 2002 | 03:44 PM
ede's Avatar
ede
every hose and wire connected to it and replace the blower box with one for a non ac car, it'll really clean it up and give you lot more room.
Old Nov 13, 2002 | 12:39 AM
nikh23's Avatar
Car: 88 IROC Convertible
Transmission: Raptor 700
back from the dead......
is there a way to do it without buying a ac delete box, in case i want to put it back into the car in the future? and what exactly comes out, a picture would be a tremendous help. i know hte compressor can come out if its being replaced by a pulley and that silver canister but i'm not entirely sure. any help wuold be apprecciated, thanks guys
Old Nov 13, 2002 | 08:56 PM
nikh23's Avatar
anybody?
Old Nov 13, 2002 | 09:15 PM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
Lets see, you can take out the condenser in front of the radiator, and the lines going back across the passenger side. The accumulator (metal can) can come out as well. If you have a serpentine setup, you must have the AC delete pulley to remove the compressor. If you have a v-belt setup, just take off the compressor. I'd recommend the AC delete heater box, it gives a ton of more space, and looks really nice. That's what's shown in the picture below. If you get the delete box, you can always go back and swap in the AC box later if you want to put the AC back on. Otherwise, if you dont want to buy the delete box, you can use the AC box, but you have to cap the lines coming out of it, so that when you turn on the heater, the air will come into the passenger compartment in the car, rather than blowing out the lines into the engine bay.
Old Nov 13, 2002 | 09:18 PM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
Also, you may want to put a jumper wire across the AC pressure switch, or your fan will run all the time. Then again, some people like the fan running all the time to keep the car cool. That's up to you. When I deleted my AC, I didn't cut off any of the wiring harnesses, in case I ever want to put AC back on. I just taped them up and tucked them out of sight. Here's a pic of the switch you'll want to jumper to keep the fan from running all the time.
Old Nov 13, 2002 | 11:41 PM
nikh23's Avatar
beatiful, exactly what i needed, thanks a lot vicious
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
ctoledo0834
Sep 18, 2015 04:16 PM
Stroopwafel
Sep 11, 2015 06:38 AM
