TIPS AND TOOLS for porting L98 aluminum heads?
Old Aug 19, 2002 | 01:22 AM
86IROCTHD's Avatar
Car: 88 Trans Am
Engine: lt1 intaked 355 makin 277 on 25 psi of fuel pressure and stock timing :)
Transmission: A4 stock... that moved a mobile dyno a foot shifting into 2nd :)
hey guys i know u cant take alot of material out of these heads but any ideas on little secrets and ideas to get them to flow good.... and what bits do i need to do it... i have a gearless angle grinder at work that i am gonna use........?
Old Aug 19, 2002 | 05:38 AM
87transam5.7tpi's Avatar
if you use carbide bits make sure you use some lubracant, I use just plain motor oil. otherwise the bits get hot and hte metal just melts to em. figured that out when I did my plenum, simeasing one set of runners took like 1 hour wihtout lubracant, 10 min wiht
Old Aug 19, 2002 | 05:18 PM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
Check out my thread here:
https://www.thirdgen.org/techbb2/sho...hreadid=117410
It has lots of pics and tips from the gurus on the board. I'm glad to see someone else taking the plunge! Good luck.
Vintageracer
Jan 10, 2020 05:33 PM
midge54
Dec 27, 2019 04:14 PM
beastin91rs
Oct 9, 2015 07:38 AM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
Dialed_In
Aug 20, 2015 01:45 PM
