Stranded :(
Old Aug 19, 2002 | 04:57 PM
i8atang's Avatar
Stranded :(
WTF happened? I got in my car this morning, and as usuall, let it warm up b/f takeoff. As I pulled onto the road, I got a cell call, so I pulled over to take it, leaving the car running. When I pulled back onto the road, I took off normal. As I went into third, I kinda punched it a little, and ran thru third to about 4500 rpm, shifting into fourth. When I let off it, the car backfired once, then the gas pedal went dead. The car was still running (burning the gas already in the motor, I assume), but even if I pressed the gas to the floor, it did nothing. In just a couple of secconds, it died, so I pulled it over. I tried ana tried to get it to fire, but no luck. Ohyeah, the ses light came on after it backfired. I jumped the terminals to check the codes, but it read a 12 every time. Is it the TPS, or what? Need help quick!!!!!
Thanks,
Kelly
Old Aug 19, 2002 | 05:41 PM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
my first thought was to check if the distributor is loose, if it became too retarded it'll backfire. can you hear the fuel pump prime when you turn the key? maybe the pump died
Old Aug 19, 2002 | 05:43 PM
i8atang's Avatar
Someone
I gotta get this fixed tonight if possible!!! Can't someone shed some light???
Old Aug 19, 2002 | 05:51 PM
i8atang's Avatar
in a minute
I am away from the car right now, but I am going to check the pump and dist. and TPS. Thanks for the help
Old Aug 21, 2002 | 08:59 AM
i8atang's Avatar
Thanks for the help U.T. I went to the car yesterday morning, pulled the dist., and found only half the dist gear teeth left on it. It did not have the required bronze gear( or so I was told), and my cam had eaten it up. The amazing thing is that my cam gear was perfect. Everyone I talked to at the local speed shops said I might as well get ready to pull it again, but they were wrong! So I just bought a comp cam bronze gearand installed it. Today I have to set the timing and change the oil.
Old Aug 21, 2002 | 03:40 PM
Car: '87 Camaro LT
Engine: 355 L98
glad to be of help
masonta
Sep 1, 2015 06:40 PM
TPIterror
Aug 27, 2002 12:53 PM
maksik7
Apr 10, 2002 11:22 PM
rezinn
Mar 2, 2002 07:20 PM
