Are all stock third gen fuel pumps in the fuel tank??
Old Aug 19, 2002 | 06:46 PM
jfox55's Avatar
Just wondering if all third gen fuel pumps are in the tank??
Old Aug 19, 2002 | 08:33 PM
WildmanDRL's Avatar
Car: 1989 Firebird Formula
Engine: 350 TBI (LO5 K)
Axle/Gears: 7.5 10 bolt peg leg
I think just the fuel injected ones.
Old Aug 19, 2002 | 08:39 PM
Anth's Iroc's Avatar
Car: 87 IROC-Z
Engine: =350 sbc
Transmission: TH350
Yeah i have an 87 LG4(carb) and the fuel pump is on the motor
Old Aug 19, 2002 | 08:50 PM
jfox55's Avatar
Anths Iroc, is your fuel pump at the bottom left hand corner of the engine on the front.
Old Aug 19, 2002 | 08:54 PM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
my SC that had an LG4 has an intank pump, i dunno if it had a mech. one too cuz i got the car w/out an engine
Old Aug 19, 2002 | 09:12 PM
jfox55's Avatar
Ukraine train
Was your car fuel injected or carb????
Old Aug 19, 2002 | 09:18 PM
Car: '87 Camaro LT
Engine: 355 L98
Originally posted by jfox55
Ukraine train
carbed
Old Aug 19, 2002 | 09:45 PM
jms's Avatar
jms
The early third-gens (carbed) had some problems with vapor lock.
One of the factory fixes was to use an in-tank mounted fuel pump in addition to the regular engine mounted fuel pump. Even on the carbed engines.
jms
Old Aug 20, 2002 | 04:05 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Wasn't that on the hi-performance optional V8's?
Old Aug 20, 2002 | 04:32 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It was even done on the low-performance standard V8s.
My HO car only has the traditional block-mounted mechanical one. There was some sort of recall or campaign, I don't know the details, where they would add the in-tank one if you had certain things happen and complained. I don't think they left the factory that way (with both kinds of pump) but I could be wrong.
In fact, the only fuel-pump related malfunction my car has ever had, would just have got worse if there was another pump. When it gets really heat-soaked, the fuel in the pump will flash as soon as it passes the needle, and the car will flood massively... gasoline spewing up out of the vents and everything. It usually does it right after I park it on a really hot day with the AC on, get out and do something like run into a store real quick, jump back in after about 2 or 3 minutes, crank it up and try to take off. It will wait exactly until I am pulling across a 55 mph 6-lane highway, and then it will stall with me blocking as many lanes as possible. It takes about 2 minutes of cranking with the starter to get it to fire again, at which point it belches a huge cloud of black smoke and then drives on as if nothing had happened. "Premium" gas, with lots of low boiling point alcohol in it, is the worst.
theshackle
Mar 5, 2017 06:37 PM
beachrodder
Aug 25, 2015 08:05 AM
AkDrifted
Aug 17, 2015 07:45 PM
kyleb24
Aug 15, 2015 08:24 AM
Kaweh
Aug 9, 2015 02:54 PM
