car won't start
Old Aug 19, 2002 | 07:27 PM
russ84HO's Avatar
car won't start
I tried to start my 89 L98 GTA a couple of days ago, but when I hit the ignition, the dash lights and gauges came on, and I could hear the fuel pump come on but that was it. The starter didn't even engage. The starter and the switch on the column were replaced this weekend, but nothing is happening still. Is it an electrical problem? I am stumped. Any help is appreciated.
russ
Old Aug 19, 2002 | 08:27 PM
jfox55's Avatar
I am assuming it is an auto right. Have you checked your neutral safety switch??
Old Aug 20, 2002 | 08:04 AM
russ84HO's Avatar
yeah, I forgot to mention that my father and I have tinkered with the neutral safety switch too. Still no luck.
Old Aug 20, 2002 | 08:12 PM
jfox55's Avatar
Maybe you should try replacing it, unless you know a way to test it. I think maybe a voltmeter might, but not sure exactly how you would do it.
Old Aug 25, 2002 | 12:59 PM
sixt8bird's Avatar
Try new starter enable relay in kick panel, if it has one.
Old Sep 26, 2002 | 04:17 PM
dale davidson's Avatar
um, do u mind elaborating on the "new starter enable relay" please?
Old Sep 26, 2002 | 06:00 PM
sixt8bird's Avatar
Its in the Kick panel .Drivers side and I believe it has something to do with the VAT if you have one. Relays all wear out after time.
midge54
Dec 27, 2019 04:14 PM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
ZsTransAm
Aug 11, 2015 07:30 PM
killer777
Aug 8, 2015 02:47 PM
