Starter makes Grinding Noise and Cranks Slow
Old Aug 24, 2002 | 01:39 AM
maksik7's Avatar
Hey Guys,
I just installed a new set of headers on my car and fixed up some singed wires. Well I go to start the car and the starter makes this weird noise (grinding sort of). Well the engine still cranks but slowly and in bursts (speeds up and slows down). The engine still catches sometimes but rarely.
Does anybody have an idea. At least can you tell me if this is a mechanical problem (bad starter) or electric.
Thanks for the help,
-Max
BTW Checked the battery and it's got plenty of juice.
Old Aug 24, 2002 | 08:06 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Has it ever done this before?
You have come up with a classic description of The Problem, where the starter bolt holes are too far from the crank. Sort of like having too many shims in it except you can't take them out.
Check your starter installation, make sure you used real starter bolts NOT regular ones; starter bolts are special, they have a shoulder right behind the threads that "dowel pins" the starter in the correct location, with regular bolts the starter can be improperly located which will act the same as the above.
Old Aug 24, 2002 | 11:17 AM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
jsut to make sure put a battery charger on for and hour and then try it again. otherwise the starter is fudged up.i would rather test the batter than buy a new starter cuz those things are a pain in the booty to put on and take offif u have long tubes
Old Aug 24, 2002 | 12:59 PM
maksik7's Avatar
I checked the batery and it is fine. Now the bolts I used are the same starter bolts that were there. (Just put engine back together 2 months ago) and I had no problems with this for teh 2 months, it just started yesterday. Anyways should I just remove the starter and put it back on in case it moved a little bit away?
Thanks,
-Max
Old Aug 24, 2002 | 03:07 PM
maksik7's Avatar
oops, dbl post
Old Aug 24, 2002 | 03:59 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
put a heat shield on that one to. protects it from headers better
theshackle
Sep 17, 2020 08:26 AM
Caspar
Jun 19, 2016 11:19 PM
hokis
Aug 9, 2015 03:57 PM
BrianI
Aug 9, 2015 11:52 AM
