A.I.R. Pump Replacement...
Old Aug 24, 2002 | 08:38 PM
sancho's Avatar
Car: '89 Chevrolet Camaro IROC-Z
Transmission: TH-700R4
Axle/Gears: B&W 2.77 Posi
Yes, that's "replacement" and not "removal"; the rebuild part that I got @ AutoZone has slanted pulley mount, causing the pump pulley to rock all over the place as it's turning...
Anyway, I took off the obvious bolts: the two holding on the black pipe to the A.I.R. redistribution valve, and then the two large Torx bolts holding the pump. The problem is, I still can't get the pump out. It moves a tiny bit, but it won't come out. Am I forgetting a bolt or something? Or is there some sort of special twisting motion that I need to try?
Thanks.
Old Aug 25, 2002 | 01:28 AM
SNAKEHUNTER's Avatar
I had the same problem. Mine would only pivot from
the bottom mounting hole. I pried it out with a large screwdriver. Over time the aluminum mounting
bracket had pressed into the pump mounting hole.
It went back in alot easier.
Hotrodboba400
Dec 10, 2019 07:07 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
Gunsbee
Sep 7, 2015 07:10 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
