alignment
alignment
What are the alignment specs for an 85 trans am? I took the car to SEARS for an alignment and then took the car on a trip about 700 miles and when I got home there was wear on the outer edge of the tires. You can see a noticeaber grove that was not there before the alignment.
Thanks.
Thanks.
Car: 4
Engine: 6
Transmission: 5
DON'T set it to the factory specs, or that will happen. Your car is probably alaigned perfectly, by the book; but it's wrong,
Post your question on the Chassis board, there's lots of people that can give you specs that actually work for these cars.
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
http://www.fl-thirdgen.org/alignmentspecs.html
here is a list of the specs for the thirdgen f-bodies. but like he said don't set the camber to +1*. set it to 0 to -.5 camber and toe to +.010* total.
