LT1 Springs on 305 heads with XE268 cam??
Old Aug 27, 2002 | 01:52 AM
LarsZ28's Avatar
Hi, I'm getting my heads rebuilt, and wanted to know if LT1 Springs are good to use with my XE268 camshaft in my 305.
Any info appreciated.. thanks
Old Aug 27, 2002 | 04:14 AM
ChrisFormula355's Avatar
Car: Junk
Engine: Junk with nitrous
Transmission: Junk with gears
I would say yes. I have "Z28" springs on the 305 heads on my girlfriends 350 which also has the 268 extreme cam, plus I've got 1.6 roller rockers on there, so the lift is well above .500. We rev it to 6K quite often and the motor sounds great so far . I think the LT1 springs would be similar to the "Z28" springs, perhaps better???
Old Aug 27, 2002 | 05:49 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
No. It's a risk not worth taking. Get the right thing and be safe.
Have you ever seen the insides of a motor when a valve spring broke and fell into the cylinder at speed? Let's just say, valve fragments being made of steel, they are incompressible, and they are harder than both pistons and head castings.
Just because one guy hasn't has his blow up on him yet, doesn't mean it's a good idea.
Old Aug 27, 2002 | 07:17 AM
ede's Avatar
ede
buy the springs to match your cam and trash the factory rotators and use aftermarket retainers.
Old Aug 27, 2002 | 08:01 AM
LarsZ28's Avatar
Thanks guys.. Ede, are the stock rotating retainers really that bad??? they are only on the intake valves right?? Getting new comp cams retainers are going to push me over my budget .. ($125AUS) .. But I trust your judegment, and am currently looking for the right ones for my stock 305 heads.
Old Aug 27, 2002 | 08:02 AM
Markolc's Avatar
Car: '87 IROC
Engine: LT1 350
Transmission: 700-R4
The LT1 springs are good to .480 lift or so I believe. Go with LT4 springs if anything, they're good to .530 lift.
Old Aug 27, 2002 | 08:22 AM
ede's Avatar
ede
DON'T use the lt1 springs, or any spring from gmpp or k motion buy a set from comp to match your cam, or lunati. personally i prefer lunati stuff but most people don't. yes the stock rotators are that bad, trash them or take them to the recycle center.
Old Aug 27, 2002 | 08:25 AM
LarsZ28's Avatar
Ok, Thanks Ede will take your advice.. ordering new comp cam retainers/locks/seals and springs
Stock valve stem size is 11/32" right? and spring is 1.250" diameter?
midge54
Dec 27, 2019 04:14 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
gta90
Sep 15, 2015 04:00 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
anesthes
Aug 8, 2015 09:37 PM
